Create Data Map
Use the Create Data Map option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaDataMap;Run)*) to create a map that shows the gridded survey data from the measurement.
UX-Analyze extension:
- AGC Dynamic Data > Review Classification
- AGC Static Data > Review Classification
- AGC Expert User > Static Data Inversion
Create Data Map dialog options
Databases | |
Prefix | Specify the databases prefix. Script Parameter: UXANALYZE.DATA_MAP_DB_PREFIX |
Target group | Select the target group from the target database. Script Parameter: UXANALYZE.TARGETGROUP |
Source group | Select the source group from the source database, which has been inverted or modelled using Invert for Sources(Static). Script Parameter: UXANALYZE.SOURCEGROUP |
ID channel | Select the ID channel from the source database. Script Parameter: UXANALYZE.TARGETID |
Database for masking | Select which database to use for masking. Script Parameter: UXANALYZE.DATABASE_MASK_OPTION |
Mask channel | Select the mask channel from the source database for which sources maps will be created. Script Parameter: UXANALYZE.TARGETMASK |
Symbol mask channel | Select the symbol mask channel from the source database, for which sources in addition to the current/selected source will be included on the maps. Script Parameter: UXANALYZE.TARGETSYMBMASK |
Output | |
Output type | Select the output file type, which can be an image or a Geosoft map. The Image option will only create PNG files for each of the maps; however, it is the faster option to quickly review the results. When the Geosoft map option is selected, the output map will also be exported to a PNG file. While the Geosoft maps take longer to create, they can be used with data-linking cursors. The PNG image is saved to your project folder in the UXANALYZE_wrk\data_maps\*Map prefix*_image sub-folder. Script Parameter: UXANALYZE.OUTPUT_TYPE |
Map prefix | Specify the Map prefix, which is combined with the target IDs to create the data map name: Prefix_target ID.map or Prefix_target ID.png if output type is Image. Script Parameter: UXANALYZE.DATA_MAP_PREFIX |
Map name | This read-only field shows the complete map path name. |
Target window size | Specify the size of the window to show. This window will be centred on the selected measurement. Script Parameters: UXANALYZE.ANOMALYWINDOW |
Data to Display | |
Source | Select Database or Grid using the radio buttons. Depending on your selection, some of the following parameters will be enabled or disabled, based on file format requirements. Script Parameter: UXANALYZE.SUBSETGDB_IS_GRID |
Grid name | If Grid is selected, specify the grid file name. Script Parameter: UXANALYZE.DATA_MAP_GRID |
Data channel prefix | If Database is selected, specify the sensor data channel from the list. Script Parameter: UXANALYZE.DATA_MAP_SENCHAN_PREFIX |
Gate | Select the gate number to display on the map. The list is from 0 to the number of gates for the selected sensor, minus one. Default value is the first non-dummy gate in the batch modeling. If no batch modeling is done, the default value is 0. Script Parameter: UXANALYZE.LOGATE |
Data to plot | Select the transmitter-receiver coil pairs to plot. The available options depend on the configuration of your sensor.
Measured, Modeled, Residual | Select the data to be displayed in the data map. Script Parameters: UXANALYZE.DISPLAY_FINAL_DATA UXANALYZE.DISPLAY_MODELED_DATA UXANALYZE.DISPLAY_RESIDUAL_DATA |
Actions | |
[Set Colour] | When selected, the Adjust Colour Scale dialog is displayed that enables the user to adjust the colours for Measured and Modeled or Residual data. |
[Set Gridding Parameters] | When selected, the Grid Parameters dialog is displayed that enables the user to set the gridding parameters for this GX. |
Once you fill in the various entries and click the OK button, the data maps, and possibly its PNG images, are created and saved in the output project folder UXANALYZE_wrk\data_maps\.
The following symbols are plotted on the output map:
X | - the flag location |
+ | - the sensor location |
![]() | - the fit location |
Sample Script
As this tool calls various tools in the background, the recorded script may contain several additional lines. Below, is a simplified sample script with the key lines that can be modified and used to run the tool:
SETINI UXANALYZE.SURVEYMODE="Static"
SETINI UXANALYZE.WINDOWSIZE="25"
SETINI UXANALYZE.ANOMALYWINDOW="2"
SETINI UXANALYZE.DATA_MAP_DB_PREFIX="test_Survey"
SETINI UXANALYZE.TARGETGROUP="targets"
SETINI UXANALYZE.SOURCEGROUP="test"
SETINI UXANALYZE.DATABASE_MASK_OPTION="0"
SETINI UXANALYZE.TARGETID="id"
SETINI UXANALYZE.TARGETMASK="mask"
SETINI UXANALYZE.TARGETSYMBMASK=""
SETINI UXANALYZE.SUBSETGDB_IS_GRID="0"
SETINI UXANALYZE._SENCHAN="Data_lev"
SETINI UXANALYZE.LOGATE="8"
SETINI UXANALYZE.MONOSTATIC_COIL=""
SETINI UXANALYZE.DISPLAY_FINAL_DATA="1"
SETINI UXANALYZE.DISPLAY_MODELED_DATA="1"
SETINI UXANALYZE.DISPLAY_RESIDUAL_DATA="1"
SETINI UXANALYZE.DATA_MAP_PREFIX="t"
SETINI UXANALYZE.OUTPUT_TYPE="1"
GX Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaDataMap;Run)
