Level Sensor Data
Use the Level Sensor Data option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaLevelData;Run)*) to subtract the background for the advanced sensors.
UX-Analyze extension:
- AGC Static Data
- AGG Dynamic Data > Drift and Background Removal
- AGC Expert User > Static Data Prep and QC
- AGC Expert User > Dynamic Data Prep and QC
Level Sensor Data dialog options
Survey database prefix | Specify the prefix for the survey databases (e.g., SAM, SFR). Script Parameter:UXANALYZE.LEVEL_SURVEY_DBPREFIX |
Group name | Select the group name. Script Parameter:UXANALYZE.LEVEL_SURVEY_GROUP |
Mask channel | Select the mask channel. Script Parameter:UXANALYZE.LEVEL_SURVEY_MASKCHAN |
Monostatic coil | Select the coil name from the list of X, Y, and Z. This selection determines which receiver coils data will be leveled. This entry is enabled only when dynamic advanced data is being leveled. Script Parameter:UXANALYZE.LEVEL_MONOSTATIC_COIL |
Sensor channel suffix | Select the sensor channel suffix, which determines which data channels will be leveled. This entry is enabled only when dynamic advanced data is being leveled. Default value is NORM. Script Parameter:UXANALYZE.LEVEL_SENCHAN_SUFFIX |
Sensor channel | Select the sensor channel. This channel should exist in both anomaly chip and background databases. This entry is enabled only when static (cued) advanced data is being leveled. Script Parameter:UXANALYZE.LEVEL_RAWSENCHAN |
Sensor channel suffix - leveled | Specify the sensor channel suffix, which will be added to the leveled data channel(s). Script Parameter:UXANALYZE.LEVEL_LEVCHAN_SUFFIX |
Sensor channel - leveled | This read-only field shows the name of the leveled sensor channel(s). |
Background database prefix | Select the prefix for the background databases (e.g., SBG, SRB). Script Parameter:UXANALYZE.LEVEL_BACKGROUND_DBPREIFX |
Group name | Select the group name. Script Parameter:UXANALYZE.LEVEL_BACKGROUND_GROUP |
Mask channel | Select the mask channel. Script Parameter:UXANALYZE.LEVEL_BACKGROUND_MASKCHAN |
Background Selection Method | Background Selection Method determines the proper line/group in the background database for each line/group in the anomaly chip database.
Script Parameter:UXANALYZE.LEVEL_CALC_METHOD |
As part of the acquisition procedure for cued and dynamic data collection with the advanced sensors, background measurements are recorded at different locations within the site and at various times. Background areas are identified as areas where there is no significant anomalous response above the noise envelop. The background data format is identical to that of anomaly data.
The background is subtracted from the anomaly data based on either location (closest background to target) or time (background with closest time), and background-removed data are saved as new channel(s) in the anomaly chip database and passed through to the inversion algorithms.
The background noise, or the difference between the closest background to the data and the closest background to the first one, is also saved as a new channel, UXA_Noise_Floor, in the anomaly chip database. Note that the UXA_Noise_Floor channel is only created when working in Static mode.
The background group/line ID, background database name and background line name are recorded in the site database under three channels, UXA_Background_ID, UXA_Background_Database and UXA_Background_Line. In case of static data, the location offset and the time offset between the background and measurement are also recorded in the target database under these channels: UXA_BACKGROUND_LOCATION_OFFSET and UXA_BACKGROUND_TIME_OFFSET.
The tool goes through all the non-masked survey lines, finds the closest group/line in the background database, and subtracts the background from the signal.
