Load Viewer Parameters
Use the Load Viewer Parameters option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaLoadViews;Run)*) to load or create one or more viewers from a previously saved file.
UX-Analyze extension:
- AGC Dynamic Data > Review Classification > Interactive Image Viewers
- AGC Static Data > Review Classification > Interactive Image Viewers
- AGC Expert User > Source Classification and Review > Interactive Image Viewers
Load Viewer Parameters dialog options
Input view file name | Select a .imgview file containing previously saved image viewers. Script Parameter: UXANALYZE.FILENAME |
