Inversion Settings
Use the Inversion Settings menu option (UXASETTINGS GX) to set the global parameters of this session of target inversion.
Inversion Settings dialog options
Target database name | The name of the database that will contain the feature parameters output from the fitting algorithms. Script Parameter:UXANALYZE.TARGETGDB |
Distance unit | Project distance units (i.e. "m"). The specified units take precedence over the database units. Script Parameter: UXANALYZE.UNITS |
Interactive mode window size | The study area is subdivided into square windows of these dimensions for analysis. Script Parameter: UXANALYZE.WINDOWSIZE |
Anomaly window size | The size of the anomaly window to model in the units specified above. This window consists of the data residing in a square centred on a selected target. Script Parameter: UXANALYZE.ANOMALYWINDOW |
Allow displaying error messages in a batch process | In long batch processes, such as batch Modelling, an error message will show up if there is a processing problem with one or more targets. This event stops the process and requires user interaction to continue. As a solution, this parameter can be set to No, which prevents the errors from showing up Script Parameter: UXANALYZE.BATCHSHOWMSG |
In the subsequent Add/Review dialogs the sub-window is extended by the anomaly window size in order to display the area in the proximity of targets potentially residing right along the border of the sub-window.
