Create Modelling Results Maps
Use the Create Modelling Results Map menu option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UceObsModMap;Run)*) to create modelling maps to visualize and report the results of the target modelling process.
UXO Marine extension:
  • UXO - Marine Grad
  • UXO - Marine Mag
Create Modelling Results Map dialog options
Target Database
Name
Select the target database. This database must contain X & Y coordinates, a target ID channel, and a mask channel.
Script Parameter: UCEOBSMODMAP.TARGETGDB
Group
Select the group to process from the currently selected target database.
Script Parameter: UCEOBSMODMAP.TARGETGROUP
ID channel
Select the target ID channel. Each target must have a unique target ID number.
Script Parameter: UCEOBSMODMAP.TARGETIDCH
Mask channel
Select the target database mask channel to filter out specific targets. Only the targets with a mask (channel value) of 1 will be processed. If the value is set to 0 or dummy (*), the corresponding target will be ignored.
If the field is left blank, no mask will be applied.
Mask channels have their CLASS attribute set to "MASK", but any channel from the drop-down list may be used as a mask channel.
Script Parameter: UCEOBSMODMAP.MASKCH
Data Group
Modelled database
Select the database that contains both observed and modelled data for each target. The name will have the form "<Survey Database>_<Target Database>_<Target Group>".
Script Parameter: UCEOBSMODMAP.MODELLEDDB
Observed channel(s)
Select the channels that have been modelled using the Model Targets (Batch) option.
Script Parameter: UCEOBSMODMAP.OBSERVEDCH
Map Parameters
Instrument type
Select the instrument type from the list of available instruments.
Script Parameter: UCEOBSMODMAP.INSTRUMENTTYPE
Grid colour table
Select a colour table (TBL, ZON, or ITR assumed).
Script Parameter: UCEOBSMODMAP.COLORTBL
Grid colour method
Select the colour method as one of the following options:
  • "As last displayed"
  • "Default"
  • "Histogram equalization"
  • "Normal distribution"
  • "Linear"
  • "Log-linear
  • Shaded relief"
If the selected colour scheme (grid colour table) is an .itr file or a .zon file, the colours are already attributed to data ranges, and this entry remains disabled.
The "As last displayed" method will display the grid as it was displayed the last time the grid was viewed, and the colour table will be ignored.
Script Parameter: UCEOBSMODMAP.COLORMETHOD
Display residual field
Check this option if the residual map is to be displayed.
Script Parameter: UCEOBSMODMAP.DISPRESIDUAL
Modelled parameters
Select the parameters that have been estimated using the Model Targets (Batch) option.
Script Parameter: UCEOBSMODMAP.MODELLEDPARAMS
Open all maps
Check this option to display the maps as they are created.
Script Parameter: UCEOBSMODMAP.DISPALLMAPS
The Create Modelling Results Map option creates a map for each target in a target group that includes the observed (measured), modelled, and residual data as grid images, as well as a table of the selected modelled parameters. The number of maps for each target is defined by the number of selected observed channels, so you may have more than one map for each target if more than one observed channel was selected. The map files are named "<Modelled Database>_<Observed Channel>_<Target Id>.map" and are saved in the subdirectory "...\_wrk\maps" inside the project directory.
Selecting a ZON or ITR file for the colour table will allow you to control how the observed and model data are displayed, for example, to display them using the same colour range as you used for the entire survey grid.
