Octant Test
Use the Octant Test option (UCEOCTANT GX) to calculate and display in cardinal directions the octant test.
Octant Test dialog options
Octant database | Specify the name of the Geosoft database that contains the Azimuthal test data. If a database is already open in Oasis montaj it will be displayed as the default database. Script Parameter: UCEOCTANT.GDB |
Data channel | The data channel to be used for the Azimuthal heading test. Script Parameter: UCEOCTANT.CHAN |
Amplitude tolerance | Specify the Amplitude tolerance. All amplitudes beyond the specified tolerance are plotted in red on the map. If left blank no amplitudes tolerance is applied. Script Parameter: UCEOCTANT.TOL |
Update list | Click the Update List button to enter a new database name and to refresh the channels list. |
OK | Proceeds with generating the map |
The amplitude heading offsets are posted at the end of each line. For clarity, the profiles are colour-coded. Amplitudes exceeding the permissible tolerance are plotted in red on the map. This GX is used to optimize the sensor orientation.
