Create/Update Dynamic Background Database
Use the Create/Update Dynamic Background Database option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaCreateBkgDatabase;Run)*) to create/update a background database from the site database and the site map. This GX works with dynamic advanced data.
UX-Analyze extension:
- AGC Dynamic Data > Drift and Background Removal
- AGC Expert User > Dynamic Data Prep and QC
Create/Update Dynamic Background Database dialog options
Action | This GX can be used to create a dynamic background database, as well as to add/remove points to/from a background database. The default action is "Add". Script Parameter: UXANALYZE.BACKGROUNDGDB_ACTION |
Survey database prefix | Select the dynamic survey database prefix. Script Parameter: UXANALYZE.DYN_SURVEY_DBPREFIX |
Group name | Select the dynamic survey group name. Script Parameter: UXANALYZE.DYN_SURVEY_GROUP |
Sensor channel suffix | Enter the sensor channel suffix, which will be used to find the sensor channels from the survey database. Sensor channels follow Rx*_Tx*_[SUFFIX] pattern, where * represents the Rx and Tx names. The field is blank by default. Script Parameter: UXANALYZE.SENCHAN_SUFFIX |
Background database prefix | Enter the background database prefix. Script Parameters:
Group name | Enter a new background group name or select an existing one. Script Parameter: UXANALYZE.DYN_BACKGROUND_GROUP |
Site map | Enter the site map, which is used to pick the background points. Script Parameter: UXANALYZE.DYNAMICMAP |
When the user selects a data point to be added to the background, the GX will average over N points on either side of the selected point (i.e., N before and N after), before adding that to the background database.
"N" can be found in "uxa.config", which can be located in the C:\Program Files\Geosoft\Desktop Applications \etc\ folder:
- <dynamicBkgDatabase>
- <averaging oneSidePoints="3" />
- </dynamicBkgDatabase>
