Save Existing Viewer Parameters
Use the Save Existing Viewer Parameters option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaSaveViews;Run)*) to save the parameters for all existing interactive image viewers to a file for later retrieval.
UX-Analyze extension:
- AGC Dynamic Data > Review Classification > Interactive Image Viewers
- AGC Static Data > Review Classification > Interactive Image Viewers
- AGC Expert User > Source Classification and Review > Interactive Image Viewers
Save Existing Viewer Parameters dialog options
Output view file name | Enter a name to create a new output file or select existing. Script Parameter: UXANALYZE.FILENAME |
Image viewers will be saved in *.imgview file format. When selecting an existing file, please make sure that it is the correct format.
