Locate Targets on Survey Lines
Use the Locate Targets on Survey Lines option (geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxoLocateTargetsOnSurveyLines;Run)*) to locate targets or find the survey line (and station) to your target list.
UXO Land extension:
  • Target Management > Target List Management
UXO Marine extension:
  • UXO - Marine Grad > Manage Target List
  • UXO - Marine Mag > Manage Target List
Locate Targets on Survey Lines dialog options
Survey Data
Database name
Select the survey database name.
Script Parameter: UXDETECT.SURVEY_GDB
Target Database
Name
Specify the name of the Target database.
Script Parameter: UXDETECT.TARGET_GDB
Group
Specify the name of the "group" to save the target data. This value is the same as the most recently specified target group from any of the other dialogs that require a Target Group.
Script Parameter: UXDETECT.TARGET_GROUP
Mask channel
Select the target database mask channel to filter out specific targets. Only the targets with a mask (channel value) of 1 will be processed. If the value is set to 0 or dummy (*), the corresponding target will be ignored.
If the field is left blank, no mask will be applied.
Script Parameter: UXDETECT.TARGET_MASK
Target value channel
Select the target value channel.
Script Parameter: UXO_LOCATE_TARGETS_ON_SURVEY_LINES.TARGET_VALUE_CHANNEL
When picking or editing targets, if the survey database is specified, the closest point of approach (line and station) to the target location will of be already determined. However, if this was missed, or during editing the information in the survey and target database is out "sync" Locate Target on Survey Line will update both databases. In the target database channels will be added that include nearest survey line, fiducial and distance along the line. In the survey database two channels are added the target id and grid value, that contain values at the point nearest to the target locations.
