Altitude QC
Use the Altitude QC option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UceAltitudeQC;Run)*) to identify and remove data that exceeds the survey altitude threshold.
UXO Marine extension:
  • UXO - Marine Grad > QC QA Tools
  • UXO - Marine Mag > QC QA Tools
Altitude QC dialog options
Current database
The name of the current database (read only).
Hovering your mouse over the name will display the full path of the current database.
Script Parameter: AltitudeQC.GDB
Altitude channel
Select the channel that contains the altitude of the sensors above the sea floor.
Script Parameter: AltitudeQC.ALTITUDE_CHANNEL
Despike
Check this option to apply a non-linear filter to the output data to remove single-point spikes. Non-linear filters, considered noise spike-rejection filters, are ideal for removing short-wavelength, high-amplitude features from data.
Leave the option unchecked (default) to bypass the "despiking" process.
Script Parameter: AltitudeQC.DESPIKE
Maximum altitude
Specify the maximum threshold (value greater than zero) for the survey altitude. Altitude values exceeding the maximum altitude will be set to dummies ("*") in the output altitude channel
Script Parameter: AltitudeQC.MAXIMUM_ALTITUDE
Output altitude channel
Specify the channel to store the output altitude values. The default is altitude channel_Corr.
Script Parameter: AltitudeQC.OUTPUT_ALTITUDECHAN
Create altitude map
Check this option to automatically generate a map of line paths and visualize where the altitudes exceed the maximum threshold. All these deviations (values that are above the acceptable range) are plotted with a single colour (red) on the map.
Script Parameter: AltitudeQC.CREATEMAP
The Altitude QC tool will identify and remove altitude data that exceeds the survey altitude threshold. The output altitude channel will contain dummy (*) values where the threshold is exceeded.
In addition, an altitude deviation flag channel ("Flag_altitude channel") is created and sets the channel values to 1 whenever the altitudes exceed the maximum altitude value (maximum threshold).
This flag or mask channel can be used to blank (dummy) out other data channels as required using either math expressions or the Copy Channel with Mask option found in the Database Tools > Channel Tools menu. You can also use the flag channel along with the symbol plotting tools (e.g., Location Plot under the Map Tools > Symbols menu) to plot where the sensor altitude exceeds the survey threshold on your own custom maps.
