Level Mag Sensors
Use the Level Mag Sensors option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxoLevelMagSensors;Run)*) from the UXO-Marine Grad > Data Corrections menu to offset one or more data channels and bring them to level with another data channel.
Level Mag Sensors dialog options
Reference sensor channel
Select the reference sensor from the channel list. This sensor will remain untouched.
This is a mandatory field.
Script Parameters:
UXO_LEVEL_MAG_SENSORS.REFERENCE_SENSOR_CHANNEL
Correction method
Select the correction method to be used in the input channel adjustment. One of the following methods may be chosen:
  • Median: For each line, calculates the difference between reference and input sensors, gets the median, adds it to the input sensor and outputs the result to levelled output sensor adjusted channel.
  • Mean: For each line, calculates the difference between reference and input sensors, gets the mean, adds it to the input sensor and outputs the result to levelled output sensor adjusted channel.
  • Constant (a value must be entered if chosen): Adds the entered value to the input sensor and outputs the result to levelled output sensor adjusted channel.
Script Parameter:
  • UXO_LEVEL_MAG_SENSORS.METHOD
Number of additional sensors
Specify the number of additional sensors to be adjusted (levelled). When this value is changed the number of rows in the grid view below (containing the input channel, levelled output channel and constant) is modified to match this value.
The default and minimum value is 1.
Script Parameter: UXO_LEVEL_MAG_SENSORS.NUMBER_ADDITIONAL_SENSORS
Output suffix
Specify the output suffix to automatically populate the levelled output channel with the corresponding input channel appended by the specified suffix.
This process occurs when either a new input channel is selected or the suffix value is updated and, at least, one input channel is set.
  • Adding an output suffix will update all the levelled output channel names in the list that have a corresponding input channel name.
  • Script Parameter: UXO_LEVEL_MAG_SENSORS.OUTPUT_SUFFIX
    Input channel
    Select the input sensor (to be adjusted) from the channel list.
    Script Parameter: UXO_LEVEL_MAG_SENSORS.INPUT_CHANNELN, where N starts at 1 up to the number of additional sensors
    Levelled output channel
    Specify a new (or existing) name for the output channel. The adjustments are performed on the input sensor and saved in this channel.
  • If at least one of the entered channels already exists, you will be prompted to confirm the channel replacement.
  • Script Parameter:
    UXO_LEVEL_MAG_SENSORS.LEVEL_OUTPUT_CHANNELN, where N starts at 1 up to the number of additional sensors.
    Constant
    Specify the constant value to be used with the Constant method.
    This is a mandatory field if the Constant method is selected. This value is ignored, otherwise.
    Script Parameter: UXO_LEVEL_MAG_SENSORS.CONSTANTN, where N starts at 1 up to the number of additional sensors.
    Levelling the sensors is useful to ensure proper calculation of gradients/derivatives (should be around zero), and to ensure the Analytic Signal will be cleaner (levelled between survey lines, with a base close to zero for all lines) to enable better target picking.
