Navigation Correction
Use the Navigation Correction option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UceNavCorr;Run)*) to correct for navigational errors.
UXO Land extension:
- Data Preparation > Path Corrections
UXO Marine extension:
- UXO-Marine Grad > Path Corrections
- UXO-Marine Mag > Path Corrections
Navigation Correction dialog options
Database | |
Name | Select the name of the database to process. Script Parameter: UCENAVCORR.GDB |
Lines to correct | Select the database lines to be corrected. Script Parameter: UCENAVCORR.LINES |
X backup channel | Specify the name of the X backup channel (original X channel). Script Parameter: UCENAVCORR.XBACK |
Y backup channel | Specify the name of the Y backup channel (original Y channel). Script Parameter: UCENAVCORR.YBACK |
Reset current X/Y with backups | Select this option to reset the current X/Y channels with the backup channels defined above. If this is not selected the current X/Y channels will be used. This option is not selected by default. Script Parameter: UCENAVCORR.RESET_XY |
Output Map | |
Output map name | Specify the name of the output map. Script Parameter: UCENAVCORR.MAP |
Orig/corr line path thickness (mm) | Specify the original and corrected line path thickness, in millimetres. Script Parameter: UCENAVCORR.LINEPATHTHICK |
Orig/corr symbol size (mm) | Specify the original and corrected symbol size, in millimetres. Script Parameter: UCENAVCORR.SYMBOLSIZE |
Current (corrected) line thickness (mm) | Specify the current (corrected) line thickness, in millimetres. Script Parameter: UCENAVCORR.LINETHICK |
Position quality symbol size (mm) | Specify the position quality symbol size, in millimetres. To enable this parameter you must first select a Quality flag channel, in the Automatic position correction options section of this dialog. The position quality symbol legend will be plotted on your map. Script Parameter: UCENAVCORR.QUALITYSYMBOLSIZE |
Keep individual corrected line map groups | Select this option and the individually corrected (manually corrected) line map groups will be saved to your map and displayed in the View/Group Manager Tool. The names of the individually corrected line map groups are derived from the database line name. Script Parameter: UCENAVCORR.KEEP_GROUPS |
Automatic Position Correction | |
Correct for zero position | Select to correct navigation readings that are zeros. Script Parameter: UCENAVCORR.CORRPOSZERO |
Correct for positional double hits | Select to correct the repeated navigation readings with a linear extrapolation (or just dummy out) between previous and next valid readings. Script Parameter: UCENAVCORR.CORRPOSREP |
Time channel | Select the name of the channel containing the time stamps, required for time double hits correction. If this field is blank, no time correction is done. Script Parameter: UCENAVCORR.TIMECH |
Quality flag channel | Select the name of the fix quality channel, required for the fixed quality correction of the navigation data. If this field is blank, no fixed quality correction is done. Script Parameter: UCENAVCORR.FQCH |
Min. acceptable quality | Specify the threshold flag below which to correct the navigation data. If left blank, it will be set to the min value of the Fix quality channel. Script Parameter: UCENAVCORR.FQMIN |
Max. acceptable quality | Specify the threshold flag above which to correct the navigation data. If left blank, it will be set to the max value of the Fix quality channel. Script Parameter: UCENAVCORR.FQMAX |
Fill corrected points | Select to interpolate or dummy out (don’t move over the corrected points): Interpolate: 1 Dummy out: 0 Script Parameter: UCENAVCORR.REPLACEPTSAUTO |
Manual Position Correction | |
Correction for jumps? | Select to manually select the segments to be corrected, while in interactive mode: Straight line: 2 Script Parameter: UCENAVCORR.CORRJUMP |
Fill corrected points | Select to interpolate or dummy out (don’t move over the corrected points): Interpolate: 1 Dummy out: 0 Script Parameter: UCENAVCORR.REPLACEPTS |
We acknowledge the co-operation of Geo-Centers in the development of this navigation correction tool. Geo-Centers have contributed its numerous years of field experience by sharing with Geosoft the methodology implemented in this tool.
The Path correction tool was developed to correct GPS navigational errors. GPS uses an array of up 28 orbiting satellites to locate positions on the Earth's surface. To provide precise coordinates in 3 dimensions a minimum of 4 satellites are required. The satellite signals are received on the ground by a receiver unit that calculates the time delay of the signal to calculate a distance from the satellite; with the distances from all available satellites a fix of position is possible. While GPS can be an extremely precise mode of surveying, there are potential errors that if left uncorrected can compromise the accuracy of the data. GPS data may contain jumps, dog-legs, and shifts that will place sensor data at the wrong coordinates.
With this navigation correction tool you can automatically correct for:
- zero positions (no data being collected),
- positional double hits (repeated position readings),
- time double hits (repeated time stamps),
- quality of position data (quality of the position based on satellite signals, positional dilution of precision (PDOP) or some other indicator).
and manually correct for:
- data jumps (radio signals from transponders multipath or suffer interference from cultural radar sources).
These corrections can be applied to all survey lines or only user selected lines. The original X,Y coordinate channels are renamed and saved as a backup within the database.
The fix quality of position data are saved in a new channel (quality_corr) in the database, in which the new flag will be set to -1 if the original fix quality value is not in the acceptable min/max range).
Navigation Manual Correction Instruction
In interactive mode users can manually select polyline or straight line points to be corrected. Exact number of "from" and "to" points for polyline must be selected for each line, while only have to pick the start and end points for straight line correction. The following directions are provided on a popup message:
Polyline correction:
- Pick original points to be moved (right mouse click and press done when finished).
- Pick new locations for the original points (right mouse click and press done when finished).
- Select another section/line for correction, or hit Esc to finish.
Straight line correction:
- Pick start/end points of a segment to straighten (right mouse click and press done when finished).
