Add Sensor Configuration
Use the Add Sensor Configuration option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaAddSensorConfiguration;Run)*) to add a new sensor configuration to the sensor table to use with the Create Depth Response Curve Plot tool.
UX-Analyze extension:
- AGC Static Data > Utilities
- AGC Expert User > Utilities
Add Sensor Configuration dialog options
Database prefix | Select the databases prefix. Script Parameter: UXANALYZE.INTERACTIVE_CLASS_DBPREFIX |
Target/Parameter database group | From the list of groups in the Target/Parameter database, select the group to read the measurement from. Script Parameter: UXANALYZE.SOURCEGROUP_INTERACTIVE |
Configuration name suffix | Enter the suffix to name your new configuration. Script Parameter: UXANALYZE.CONFIGURATION_SUFFIX |
The tool will read the sensor parameters from your databases and create a new entry in the sensor table. The Target/Parameter database should contain the following channels:
UXA_GateCentersUXA_ReceiverCoilVerticesUXA_ReceiverTurnsUXA_ReceiverExtentsUXA_ReceiverNormalVectorsUXA_ReceiverGainsUXA_TransmitterCoilVerticesUXA_TransmitterTurnsUXA_TransmitterExtentsUXA_TransmitterNormalVectorsUXA_DecayTimeUXA_GateFirstValidTimeUXA_EquipmentVersion
Sensor Table
The default sensor table file, "SensorTableAdvanced.xml", is in the "C:\Program Files\Geosoft\Desktop Applications \etc" folder. When you add a new sensor configuration, the edited file is stored in the "%USERPROFILE%\Documents\Geosoft\Desktop Applications \etc" folder.
