Pick Target Locations from Current Map
Use the Pick Target Locations from Current Map option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaPickTargetLocationsFromMap;Run)*) to manually pick the peak locations from the Coherence Anomaly and/or Amplitude grids. The results will be saved into the target database.
UX-Analyze extension:
  • AGC Dynamic Data > Manage Targets
  • AGC Expert User > Dynamic Data Target Picking
Pick Target Locations from Current Map dialog options
Database prefix
Select the sensor (data) database prefix.
Script Parameter: UXANALYZE.DYN_PICK_DBPREFIX
Anomaly Grids
Model coherence
Select the model coherence grid name.
  • Model coherence grid should be entered if the Amplitude grid is blank.
  • Script Parameter: UXANALYZE.DYN_PICK_COH_GRID
    Amplitude
    Select the amplitude grid name.
  • Amplitude grid should be entered if the Model coherence grid is blank.
  • Script Parameter: UXANALYZE.DYN_PICK_AMP_GRID
    Snap to closest peak
    There are three options to select from:
    • Model coherence: for each point, the closest peak from the Model coherence grid will be saved into the target database.
    • Amplitude: for each point, the closest peak from the Amplitude grid will be saved into the target database.
    • None: for each point, the Model coherence and/or Amplitude grid values will be saved into the target database.
    Model coherence is the default.
    Script Parameter: UXANALYZE.SNAP_TO_PEAK
    Survey Target Database
    Name
    Displays the name of the target database, which will be created if it doesn't exist.
    Group
    Specify the target group name. The group will be created if it doesn't exist.
    Script Parameter: UXANALYZE.TARGETGROUP
    Id channel
    Specify the target id channel name. The channel will be created if it doesn't exist.
    Script Parameter: UXANALYZE.TARGETID
    Mask channel
    Specify the target mask channel name. The channel will be created if it doesn't exist.
    Script Parameter: UXANALYZE.TARGETMASK
    Targets
    Select to either Append or Overwrite the group of digitized targets.
    Script Parameter: UXANALYZE.APPEND
    The output channels saved into the target database are: UXA_Flag_X, UXA_Flag_Y, UXA_Target_Id, UXA_Mask, UXA_Mask_QC, UXA_ModCoh_Value, UXA_Amp_Value, UXA_PeakType and UXASensorHeight.
    UXA_PeakType channel is an indicator to identify the source and its value is "FromMap".
