Plot Background and Survey Locations
Use the Plot Background and Survey Locations option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaFlagLocationPlot;Run)*) to create a map and plot static data and background locations.
UX-Analyze extension:
- AGC Static Data > Sensor Tests and QC Tools
- AGC Expert User > Static Data Prep and QC
Plot Background and Survey Locations dialog options
Survey Target Database | |
Name: | Select the survey target database. Script Parameter: UXANALYZE.TARGETGDB |
Group | Select the survey target group. Script Parameter:UXANALYZE.TARGETGROUP |
ID channel | Select the survey target ID channel. Script Parameter:UXANALYZE.TARGETID |
Mask channel | Select the survey target mask channel. Script Parameter:UXANALYZE.TARGETMASK |
Background Target Database | |
Name: | Select the background target database. Script Parameter: UXANALYZE.BACKGROUND_TARGETGDB |
Group | Select the background target group. Script Parameter:UXANALYZE.BACKGROUND_TARGETGROUP |
ID channel | Select the background target ID channel. Script Parameter:UXANALYZE.BACKGROUND_TARGETID |
Mask channel | Select the background target mask channel. Script Parameter:UXANALYZE.BACKGROUND_TARGETMASK |
Output | |
New map, Existing map | Select whether a new map is created or an existing one is used. Script Parameter:UXANALYZE.SURVEY_BACKGROUND_MAP_SELECTION |
Name | Select the map name. Script Parameter: UXANALYZE.SURVEY_BACKGROUND_MAP |
Map template (page) | Select a standard template to be used to define the map layout. The map layout includes the media size, map margins and basic map drawing style. Script Parameter:UXANALYZE.MAP_TEMPLATE |
Map scale | The desired map scale. If left blank, a default scale will be chosen to fit the data range to the specified template. The Script Parameter:UXANALYZE.MAP_SCALE |
Survey symbol | Select the survey symbol. Default value is circle. Script Parameter:UXANALYZE.SURVEY_SYMBOL |
Size (mm) | Specify survey symbol size in mm. Default value is 2. Script Parameter:UXANALYZE.SURVEY_SYMBOL_SIZE |
Background symbol | Select the background symbol. Default value is triangle. Script Parameter:UXANALYZE.SURVEY_SYMBOL |
Size (mm) | Specify background symbol size in mm. Default value is 2. Script Parameter:UXANALYZE.BACKGROUND_SYMBOL_SIZE |
Post id labels | When selected, survey and background ids will be posted on the map. This option is not selected by default. Script Parameter:UXANALYZE.POST_LABEL_SELECTED |
[More] | |
Survey Location Symbols | |
Line weight | Select the survey line weight. Default value is light. Script Parameter:UXANALYZE.SURVEY_LINE_WEIGHT |
Line colour | Select the survey line colour. Default value is black. Script Parameter:UXANALYZE.SURVEY_LINE_COLOR |
Fill colour | Select the survey fill colour. Default value is white. Script Parameter:UXANALYZE.SURVEY_FILL_COLOR |
Background Location Symbols | |
Line weight | Select the background pass and fail line weights. Default values are light and light. Script Parameter:
Line colour | Select the background pass and fail line colours. Default values are green and red. Script Parameter:
Fill colour | Select the background pass and fail fill colours. Default values are white and red. Script Parameter:
Id Label Posting | |
Size (mm) | Specify the size of posting characters in mm. Default value is 2. Script Parameter:UXANALYZE.POST_SIZE |
Posting location | The posting location relative to the sample station (9 positions to choose from). Default value is Above right. Script Parameter:UXANALYZE.POST_REF_POINT |
Horizontal offset (mm) | Horizontal distance (mm) in which the postings are offset from the sample station. Default value is 2. Script Parameter:UXANALYZE.POST_OFFSET_X |
Vertical offset (mm) | Vertical distance (mm) in which the postings are offset from the posting station. Default value is 2. Script Parameter:UXANALYZE.POST_OFFSET_Y |
Colour | Select the posting colour. Default value is black. Script Parameter:UXANALYZE.POST_COLOR |
