Merge Data
Use the Merge in Ground Truth/Other Data option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaMergeData;Run)*) to merge data from an IVS, Flag, or Ground Truth database to the target database.
UX-Analyze extension:
  • AGC Static Data
  • AGC Expert User > Source and Library Management
Merge Data dialog options
Type
Select the merge type from the following list of items:
  • IVS: used to merge in the information of the IVS objects.
  • Flag: used to merge in the initial picked or flagged location from the dynamic survey.
  • Survey ground truth - using Geo and Flag ID: used to merge in ground truth of select targets that may be used for training or validation. The merge is done based on Geo and Flag ID.
  • Survey ground truth - using location: used to merge in ground truth of select targets that may be used for training or validation. The merge is done based on the location.
Each type requires that certain channels in the target database to be merged from the IVS, Flag or Ground Truth database, as specified below:
  • IVS:
    • UXA_GT_X
    • UXA_GT_Y
    • UXA_GT_BGS
    • UXA_GT_DESCRIPTION
  • Flag:
    • UXA_FLAG_X
    • UXA_FLAG_Y
  • Ground truth:
    • UXA_GT_X
    • UXA_GT_Y
    • UXA_GT_BGS
    • UXA_TOI_FLAG (This channel is filled with 1, 0, DUMMY which corresponds to TOI, nonTOI and no Ground truth)
  • The UXA_*_X and UXA_*_Y, channels will also be merged into the assigned X and Y channels in the target database for the IVS and Flag options.
Script Parameter: UXANALYZE.MERGE_SOURCETYPE
Merge Data From
Name
Specify the name of the IVS, Flag or Ground Truth database.
Script Parameter: UXANALYZE.MERGE_SOURCEGDB
Group
Select the IVS, Flag or Ground Truth database group.
Script Parameter: UXANALYZE.MERGE_SOURCEGROUP
Mask channel
Select the IVS, Flag or Ground Truth mask channel.
Script Parameter: UXANALYZE.MERGE_SOURCEMASK
Merge Data Into
Name
Specify the name of the target database. This should be an existing database.
Script Parameter: UXANALYZE.SOURCEGDB
Group
Select the target group.
Script Parameter: UXANALYZE.SOURCEGROUP
Mask channel
Select the mask channel.
Default channel is UXA_MASK.
Script Parameter: UXANALYZE.SOURCEMASK
Channel mapping
Select the corresponding IVS, Flag or Ground Truth database channels for the specified target channels, add new IVS, Flag or Ground Truth-target channel pair, or remove existing pairs.
In order to remove a row, select the row by clicking on the first column, then press the "Delete" key.
  • If the row is in edit mode, it has to be set to select mode first before deleting. In order to change the status, click on another row.
    The edit mode is recognized by icon displayed in the first column.
  • Script Parameter: UXANALYZE.SOURCE_TARGET_MAPPING
    Merge Options
    Merge distance (m)
    Enter the search distance.
    Default value is 0.5.
    Script Parameter: UXANALYZE.MERGE_DISTANCE
    Merge to closest flag
    Select one of the following options:
    • Ground truth item: find the nearest GroundTruth object to the target, within the search radius.
    • TOI: find the nearest GroundTruth TOI within the search radius.
    Script Parameter: UXANALYZE.MERGE_FINDTOI
    The records in the IVS, Flag or Ground Truth database will be merged into the target database based on the target geo id and flag id channels.
