Pick Target Locations from Grids
Use the Pick Target Locations from Grids option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaPickTargetLocations;Run)*) to pick the peak locations from the Coherence Anomaly and/or Amplitude grids using the Blakely peak picking method. The threshold for Model Coherence grid is established using the Determine Coherence Anomaly Threshold tool. The results will be saved into the target database.
UX-Analyze extension:
- AGC Dynamic Data
- AGC Expert User > Dynamic Data Target Picking
Pick Target Locations from Grids from dialog options
Database prefix | Select the sensor (data) database prefix. Script Parameter: UXANALYZE.DYN_PICK_DBPREFIX |
Anomaly Grids | |
Model coherence | Select the model coherence grid name. Script Parameter: UXANALYZE.DYN_PICK_COH_GRID |
Threshold | Specify a grid value below which you want peaks to be removed from the list. You can determine a reasonable threshold by using Determining Coherence Threshold tool. Script Parameter: UXANALYZE.DYN_PICK_COH_THRESHOLD |
Amplitude | Select the amplitude grid name. Script Parameter: UXANALYZE.DYN_PICK_AMP_GRID |
Threshold | Specify a grid value below which you want peaks to be removed from the list. Script Parameter: UXANALYZE.DYN_PICK_AMP_THRESHOLD |
Survey Target Database | |
Name | Displays the name of the target database, which will be created if it doesn't exist. |
Group | Specify the target group name. The group will be created if it doesn't exist. Script Parameter: UXANALYZE.TARGETGROUP |
Id channel | Specify the target id channel name. The channel will be created if it doesn't exist. Script Parameter: UXANALYZE.TARGETID |
Mask channel | Specify the target mask channel name. The channel will be created if it doesn't exist. Script Parameter: UXANALYZE.TARGETMASK |
[More] | |
Anomaly merge distance (m) | Specify the anomaly merge distance. If a Model coherence pick is within this distance from an Amplitude pick, discard the Amplitude pick, set the UXA_PeakType channel to "Both". Default value is 0.2. Script Parameter: UXANALYZE.DYN_PICK_MERGE_DISTANCE |
No of passes of smoothing filter | Specify the number of passes of smoothing (Hanning) filter to apply to the grid so that low amplitude, high frequency ‘noise’ targets will not be picked. The grid will not be smoothed if you enter 0 (zero) or leave the entry blank. More filter passes tend to reduce the number of peaks found. The default is 0. The system applies 9-point (3x3) Hanning smoothing filter to the grid, if smoothing is desired. The coefficients of the filter are: 0.06 0.10 0.06 0.10 0.36 0.10 0.06 0.10 0.06 Script Parameter:
Level of peak detection | The Blakely method is used to find peaks in a grid. For each grid cell, the GX compares its value with the values of its eight (8) nearest grid cells in four directions (along the row, along the column, and along both diagonals). There are four sensitivity levels which may be used to determine whether a grid cell will be selected as a peak: Normal (4) - grid values in all of the nearest grid cells are lower More peaks (3) - grid values in any three directions are lower Even more peaks (2) - grid values in any two directions are lower All ridge peaks (1) - grid values in one direction are lower Selecting Normal (4) (default) finds fewer peaks. To find all ridges, use All ridge peaks (1) option. Script Parameter:
The output channels saved into the target database are: UXA_Flag_X, UXA_Flag_Y, UXA_Target_Id, UXA_Mask, UXA_Mask_All, UXA_ModCoh_Value, UXA_Amp_Value, UXA_PeakType and UXASensorHeight.
UXA_PeakType channel is an indicator to identify the source grid, and can be one of these values: "ModCoh", "Amp", or "Both".
