Add Library Item
Use the Add Library Item option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaAddLibraryItem;Run)*) to create and/or populate a signature library database from items located in a source database.
UX-Analyze extension:
- AGC Static Data > Create a Site Specific Library
- AGC Expert User > Source and Library Management
Add Library Item dialog options
Source Database | |
Name | Specify the source database name. Script Parameter: UXANALYZE.SOURCEGDB |
Group | Select the source group. Script Parameter: UXANALYZE.SOURCEGROUP |
Mask channel | Select the source mask channel. Script Parameter: UXANALYZE.TARGETMASK |
Library Database | |
Name | Specify the signature library database name. This can be either an existing or a new database. Script Parameter: UXANALYZE.LIBRARYGDB |
Group | Select/enter the library group. For an existing group, the items will be appended to the group. Script Parameter: UXANALYZE.LIBRARYGROUP |
Item description channel | Select the item description channel. Script Parameter: UXANALYZE.ITEM_DESCRIPTION_CHANNEL |
IVS mode | Select the IVS mode. When selected, the IVS reference date will be enabled, and the number of required channels in Channel mapping table is changed. This option is not selected by default. Script Parameter: UXANALYZE.IVS_MODE |
Channel mapping | Pick the corresponding source channels for the required library channels, add new source-library channel pair, or remove existing pairs. Here is the list of required channels, which are specified by non-empty labels:
In order to remove a row, select the row by clicking on the first column, then, hit Delete key: The edit mode is recognized by ![]() Script Parameter: UXANALYZE.CHANNEL_MAPPING |
[Add Fit Channels] | When clicked, all the channels in the source database staring with UXA_FIT_ or FIT_ will be inserted to the channel mapping table. |
IVS reference date | Select the IVS reference date method:
Script Parameter: UXANALYZE.IVS_DATE_METHOD |
Flag-Measurement table | This table is visible when Manually set from list is selected, and is populated with the geo-flag ID, measurement ID and date from the source database. You have the option of changing the measurement ID for each flag ID. Script Parameter: UXANALYZE.FLAG_MEASUREMENT_MAPPING |
When the Add Library Item GX executes, the library database will be created if it doesn’t already exist, and the items in the source database will be inserted into the library database.
