Decay Display - QC
Use the Decay Display - QC option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaDecayDisplayQc;Run)*) to plot the measured decay of the coils from the advanced EM sensors, such as TEM2x2 and MetalMapper.
UX-Analyze extension:
- AGC Static Data > Sensor Tests and QC Tools
- AGC Expert User > Static Data Prep and QC
Decay Display - QC dialog options
Databases | |
Prefix | Specify the databases prefix. Script Parameter:UXANALYZE.DD_PREFIX |
Display | Select the way the data is displayed. Available options are:
Default: Individual. Script Parameter:UXANALYZE.DD_DISPLAY_ITEMS |
Target group | Select the target group from the list. Default: Target Script Parameter:UXANALYZE.TARGETGROUP |
ID channel | Select the ID channel using the list. For all data types except backgrounds, this is usually the Target ID; for background use the Background ID. Default: UXA_Target_ID Script Parameter:UXANALYZE.TARGETID |
Mask channel | Select the mask channel using the list. Default: UXA_Mask Script Parameter:UXANALYZE.TARGETMASK |
Location ID channel | Select the location ID channel from the list of channels in the survey database. This field is enabled only when Overlaid by location ID is selected as the Display option. Default channel: UXA_BG_LOCATION. Script Parameter:UXANALYZE.LOCATIONIDCHAN |
Sensor channel | Select the sensor channel using the list. Script Parameter:UXANALYZE._SENCHAN |
Low gate | Select the low gate value.Typically, the first usable (not effected by the primary) gate. Script Parameter:UXANALYZE.LOGATE |
High gate | Select the high gate value.Typically, the last available gate. Script Parameter:UXANALYZE.HIGATE |
Tx coil channel | Select the transmitter coil (Tx) channel from the list of channels in the Data database. Script Parameter:UXANALYZE.TXCOILCHANL |
Rx coil channel | Select the receiver coil (Rx) channel from the list of channels in the Data database. Script Parameter:UXANALYZE.RXCOILCHAN |
Output Plot | |
Colour table | Select the colour table file to use in your output image, from the C:\Program Files\Geosoft\Desktop Applications \tbl\geophysics folder. |
Plot prefix | Specify an image prefix to uniquely name your plots. Script Parameter:UXANALYZE.DD_MAP_PREFIX |
Plot name | This field is read only; it displays the file path. Script Parameter:N/A |
Plots to generate | Select which transmitter and receiver pairs will be plotted: coaxial, coincident, monostatic, a specific pair or all pairs. See Applications Notes below for more details. Default: All Script Parameter:UXANALYZE.DD_MAP_ALL
Data range | Data range determines the vertical extent of the plots. Enter the range manually or use the
If left blank, the default values will be retrieved from the survey database. Min and max values should be greater than 0.001 as the plots have logarithmic axes. Script Parameters: |
Overlay background noise | If selected, the background noise will be overlaid on the output image. The background noise channel, UXA_Noise_Floor, is created by executing Level Sensor Data. Default: Selected if UXA_Noise_Floor exists. Script Parameter:UXANALYZE.DD_OVERLAY_BKG_NOISE |
Save plot as map | If selected, the plot will also be saved as a MAP file. When using Overlaid or Overlaid by location ID, creating a map and using the data-linking cursor can be helpful in determining which measurements are outliers. Script Parameter:UXANALYZE.DD_EXPORT |
For a measurement, the Decay Display – QC plots allow you to view the transient data for various transmitter and receiver combinations. This is useful when reviewing the data for quality control. To simplify the plot, you can select from several standard combinations or pairs:
- Specific – the plot includes a single graph for the selected pair.
- Coaxial – the plot includes graphs for each pair that have the same normal vector; the coils are in the same direction.
- Coincident – the plot includes graphs for each pair that are coincident or collocated; the coordinates of the center of both coils are the same.
- Monostatic – the plot includes graphs for each pair that are coaxial and coincident.
- All – the plot includes graphs for all pairs.
If the background or survey quality control statistics have been calculated, the graph is highlighted (yellow) for the transmitter-receiver combinations that fail the QC statistics. In the ‘Data’ database, the combinations are indicated in the QC flag channels; that is equal to 1.
The QC flag channels are:
- UXA_Saturated_Flag
- UXA_Flatlined_Flag
- UXA_Current_Flag
Leveling the sensor data, calculates the background noise at the site (channel UXA_Noise Floor in the Data database). It is useful to overlay this on the graphs by selecting Overlay background noise.
The plots are named using the conventions outlined below, where: [PREFIX] is the prefix entered in the Plot Prefix entry, [GROUP] is the Data database line/group name, [TXINDEX] is the transmitter coil index retrieved from the Tx coil channel, and [LOCATION_ID] is the location ID from the Location ID channel.
- For individual measurements:
- [PREFIX]_[GROUP].png, if the image contains the data for the same transmitter and receiver coils.
- [PREFIX]_[GROUP]_Tx[TXINDEX].png, if each transmitter coil is plotted in a separate image.
- [PREFIX]_[GROUP]_all.png, if the image contains all transmitter and receiver coils.
- For overlaid measurements:
- [PREFIX]_overlaid.png, if the image contains the data for the same transmitter and receiver coils.
- [PREFIX]_overlaid_Tx[TXINDEX].png, if each transmitter coil is plotted in a separate image.
- [PREFIX]_overlaid_all.png, if the image contains all transmitter and receiver coils.
- For overlaid measurements by location ID:
- [PREFIX]_[LOCATION_ID]_overlaid.png, if the image contains the data for the same transmitter and receiver coils.
- [PREFIX]_[LOCATION_ID]_overlaid_Tx[TXINDEX].png, if each transmitter coil is plotted in a separate image.
- [PREFIX]_[LOCATION_ID]_overlaid_all.png, if the image contains all transmitter and receiver coils.
