Add Sensor Configuration
Use the Add Sensor Configuration option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaAddSensorConfiguration;Run)*) to add a new sensor configuration to the sensor table to use with the Create Depth Response Curve Plot tool.
UX-Analyze extension:
  • AGC Static Data > Utilities
  • AGC Expert User > Utilities
Add Sensor Configuration dialog options
Database prefix
Select the databases prefix.
Script Parameter: UXANALYZE.INTERACTIVE_CLASS_DBPREFIX
Target/Parameter database group
From the list of groups in the Target/Parameter database, select the group to read the measurement from.
Script Parameter: UXANALYZE.SOURCEGROUP_INTERACTIVE
Configuration name suffix
Enter the suffix to name your new configuration.
Script Parameter: UXANALYZE.CONFIGURATION_SUFFIX
The tool will read the sensor parameters from your databases and create a new entry in the sensor table. The Target/Parameter database should contain the following channels:
UXA_GateCenters
UXA_ReceiverCoilVertices
UXA_ReceiverTurns
UXA_ReceiverExtents
UXA_ReceiverNormalVectors
UXA_ReceiverGains
UXA_TransmitterCoilVertices
UXA_TransmitterTurns
UXA_TransmitterExtents
UXA_TransmitterNormalVectors
UXA_DecayTime
UXA_GateFirstValidTime
UXA_EquipmentVersion
Sensor Table
The default sensor table file, "SensorTableAdvanced.xml", is in the "C:\Program Files\Geosoft\Desktop Applications \etc" folder. When you add a new sensor configuration, the edited file is stored in the "%USERPROFILE%\Documents\Geosoft\Desktop Applications \etc" folder.
