Calculate Size and Decay Channels
Use the Calculate Size and Decay Channels option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaCalculateSizeDecay;Run)*) from the menu AGC Expert User > Static Data Inversion, for each of the sources, to calculate the size (total polarizability magnitude) and decay channels in a source or library database.
Calculate Size and Decay Channels dialog options
| Database | Select the database. Script Parameter: UXANALYZE.SIZE_DECAY_GDB |
| Gates | Select the Low and Decay gates from the list of available time gates.
 Script Parameters:
| Size channel | Select the target size channel. Defaults to 'UXA_SIZE'. Script Parameter: UXANALYZE.TARGETSIZE |
| Decay channel | Select the target decay channel. Defaults to 'UXA_DECAY'. Script Parameter: UXANALYZE.TARGETDECAY |
The Size (UXA_SIZE) and Decay (UXA_DECAY) array channels are calculated using:
Where  are the primary, secondary, and tertiary polarizabilities, respectively.
In addition to the Size and Decay array channels, three additional channels are created:
- The "low gate value" of the Size channel (UXA_SIZE##, where ## is the low gate value). The Script parameter used to create this channel is: UXANALYZE.TARGETSIZE_SINGLE
- The "decay gate value" of the Decay channel (UXA_DECAY##, where ## is the decay gate value). The Script parameter used to create this channel is: UXANALYZE.TARGETDECAY_SINGLE
- The "predicted size" channel (UXA_SIZE_PREDICTED). This channel is based on the low gate value (8, 15) of the Size channel and is categorized as follows: - UXA_Size
 (default low gate)- Category- Approximate Diameter- Less than 0.5 - Small - Less than 40mm - Less than 1.3 - Medium - 60 to 80 mm - 1.3 or greater - Large - Greater than 100mm
Working with Scripts
When working with scripts with the Calculate Size and Decay Channels dialog, it is recommended that you use the following minimized script files (saved in *.gs format), rather than recording a new script file.
MetalMapper example:
TEM2x2 example:
| SETINI UXANALYZE.SIZE_DECAY_GDB=".\\TEM_Survey_Source.gdb" SETINI UXANALYZE.TARGETSIZE="UXA_SIZE" SETINI UXANALYZE.TARGETDECAY="UXA_DECAY" SETINI UXANALYZE.LOGATE="15" SETINI UXANALYZE.THRESHOLDGATE="72" GX Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaCalculateSizeDecay;Run) |
