Determine Coherence Anomaly Threshold
Use the Determine Coherence Anomaly Threshold option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaDetermineCoherenceAnomalyThreshold;Run)*) to help you decide the cut off to use when picking targets from the model coherence anomaly grid.
UX-Analyze extension:
  • AGC Dynamic Data > Coherence Anomaly
  • AGC Expert User > Dynamic Data Prep and QC
Determine Coherence Anomaly Threshold dialog options
Database prefix
Select the sensor (data) database prefix.
Script Parameter: UXANALYZE.DYN_DBPREFIX
Lines to process from located database
Select which lines to process: Selected lines or All lines. They will be read from the Located database.
Default: Selected lines
Script Parameter: UXANALYZE.LINES_TO_PROCESS
Sensor channel suffix - leveled
Specify the sensor channel suffix for the levelled/background removed data.
Default: Norm_Lev
Script Parameter: UXANALYZE.SENCHAN_SUFFIX
Gates
Select the low and high time gates from the list, which limit the range of data used when modelling the data.
Default, low gate: gate value based on UXA_GateFirstValidTime channel
Default, high gate: the maximum gate number
Script Parameters:
  • UXANALYZE.DYN_LOGATE
  • UXANALYZE.DYN_HIGATE
Pitch channel
Specify the pitch channel.
Default: UXA_Pitch_Filt
Script Parameter: UXANALYZE.PITCH
Roll channel
Specify the roll channel.
Default: UXA_Roll_Filt
Script Parameter: UXANALYZE.ROLL
Heading channel
Specify the heading channel.
Default: UXA_COG (Course Over Ground)
Script Parameter: UXANALYZE.YAW
Amplitude channel
Specify the amplitude channel.
Script Parameter: UXANALYZE.AMPLITUDE
Anomaly grid cell size (m)
Enter the cell size for the amplitude anomaly grid.
It should be chosen to properly define the anomalies; the typical range is usually 0.1 to 0.5 metres. The grid will be named:  [PREFIX]_[DATATYPE]_AmpAnomaly.grd.
Default: 0.1 metre.
Script Parameter: UXANALYZE.COHERENCE_ANOMALY_GRID_CELL_SIZE
[Adv. Grid Parameters]
When selected, the Grid Parameters dialog is displayed; that enables you to set the additional gridding parameters.
Library database
Select the signature library database.
Script Parameter: UXANALYZE.LIBRARYGDB
Library group
Select the library group.
Script Parameter: UXANALYZE.LIBRARYGROUP
Description channel
Select the channel that contains the name or description of the items. Typically, this is the Library ID channel.
Script Parameter: UXANALYZE.LIBRARYID
TOI
Pick the selected TOI. The list is populated from the values in Description channel.
Script Parameter: UXANALYZE.FWDMODEL_TOI
Project depth (m)
Enter your project TOI depth.
Default: none
Script Parameter: UXANALYZE.COHERENCE_ANOMALY_PROJECT_DEPTH
Background amplitude threshold
Non-editable parameter. The background amplitude threshold value is calculated automatically based on the TOI and Project depth parameters.
Default: none
Script Parameter: UXANALYZE.COHERENCE_ANOMALY_AMP_THRESHOLD
Minimum depth (m)
Enter the minimum TOI depth.
Default: 0 metres.
Script Parameter: UXANALYZE.COHERENCE_ANOMALY_MIN_DEPTH
Maximum depth (m)
Enter the maximum TOI depth.
Default: 2 metres
Script Parameter: UXANALYZE.COHERENCE_ANOMALY_MAX_DEPTH
Probable source depth (m)
Enter the probable source depth for your project and TOI.
Default: 0.2 metres
Script Parameter: UXANALYZE.PROBABLE_SOURCE_DEPTH
Plot file name suffix
Enter the file name suffix, which will be added to the default names for coherence anomaly database and output plot:
Coherence anomaly database: [PREFIX]_[DATATYPE]_CohAnomaly_[SUFFIX].gdb
Coherence anomaly plot: CohAnomaly_[SUFFIX].png
Default: Blank
Script Parameter: UXANALYZE.COHERENCE_ANOMALY_THRESHOLD_SUFFIX
[More]
Data chip cross-line dimension (m)
Enter the data chip cross-line dimension.
This dimension should extend across at least 3 survey lines.
Default: 1.6
Script Parameter: UXANALYZE.DATACHIP_CROSS_LINE
Data chip along-line dimension (m)
Enter the data chip along-line dimension.
This dimension should extend along the line approximately 1.5 times the sensor array length.
Default: 1.2
Script Parameter: UXANALYZE.DATACHIP_ALONG_LINE
Number of samples
Enter the number of samples.
Default: 2000
Script Parameter: UXANALYZE.COHERENCE_ANOMALY_NO_SAMPLES
Based on the project depth, the Determine Coherence Anomaly Threshold plots will help you decide on the cut off to use when picking targets (Pick Target Locations) using the grid created by Determine Model Coherence Anomalies. The threshold plot can be found in the \UXANALYZE_wrk\Coherence Threshold folder.
The processing steps are:
  • Grid and threshold the amplitude data, by masking out data above a background amplitude threshold value.
    • Calculate the percentage of the site below the background threshold.
    • Warn the user if less than 20%, with the option to stop. This value is stored in uxa.config as <modelCoherence/gridPointsThreshold>.
  • From the amplitude data below the background threshold, locations are picked at random, up to the Number of Samples. While you can use a lower number of samples in your initial testing, we recommend using 2000, as this makes it easiest to reliably determine the coherence anomaly threshold.
  • For each location, extract a data chip (window). The data chip (window) is checked to ensure it contains at least 15 (the minimum number of points in the data chip) of valid data measurements, and all the data points are below the background threshold. Otherwise, pick another location. The minimum number of points in the data chip is saved in uxa.config as <modelCoherence/minNoOfPointsInDataChip>.
  • Calculate a synthetic (forward) model of the selected TOI and add the synthetic response to a copy of the data chip.
    • The model uses the item at a horizontal orientation, but with a random azimuth and random depth.
      • Azimuth can range between 0 to 359.
      • Depth can range from Depth Min to Depth Max.
  • Invert the data using single dipole model for both the data chips; with the added synthetic TOI response and without (blank).
    • Record in a GDB:
      • the X and Y of the window center
      • the RMS Noise of the blank (without) chip
      • the Fit_Coh from the inversion of blank (without) chip
      • the Fit_Coh from the inversion with synthetic TOI chip
      • the depth (used for the synthetic model)
      • the azimuth (used for the synthetic model)
  • Create a plot of Depth vs Fit_Coh.
    • A graph of depth vs maximum amplitude (monostatic z). With a horizontal line at 5 times the average RMS, of the maximum amplitude (monostatic z).
    • A graph of depth vs coherence.
    • Both graphs show the result from the inversion with the synthetic TOI response in black and without (blank) in red, along with a vertical line for the Project depth.
    • Also included are small Polarization Plots of the TOI. Below, the following parameters are listed:
      • Database prefix name
      • TOI
      • Background Amplitudes Threshold
      • Percentage of the site below the Amplitude Threshold
      • Number of samples used
      • Date and time the plot was created
