Perform Self (Cluster) Match
Use the Perform Self (Cluster) Match option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaPerformSelfMatch;Run)*) from the AGC Expert User > Source and Library Management menu to classify the targets against a master signature library.
Perform Self Match dialog options
Source Database | |
Name | Specify the source database. Script Parameter:UXAPERFORMSELFMATCH.TARGET_DATABASE_NAME |
Group | Select the source group. Script Parameter:UXAPERFORMSELFMATCH.TARGET_DATABASE_GROUP |
ID channel | Select the source ID channel. Script Parameter:UXAPERFORMSELFMATCH.TARGET_DATABASE_ID |
Mask channel | Select the source mask channel. Script Parameter:UXAPERFORMSELFMATCH.TARGET_DATABASE_MASK |
Mask channel - all solutions | Select the source mask channel for all solutions. Script Parameter:UXAPERFORMSELFMATCH.TARGET_DATABASE_MASK |
Match channel suffix | Select/specify the channel suffix. Channel suffix will be added to "UXA_LmStat_" and "UXA_LmID_" prefixes to create match statistics and match ID channel names. Script Parameter:UXAPERFORMSELFMATCH.CHANNEL_SUFFIX |
Match statistics channel | Read only field - contains match statistics channel name. Match statistics metric shows the degree of match between a target and the items in the signature library, so its size would be the same as the number of items in the signature library. Script Parameter:UXAPERFORMSELFMATCH.MATCH_STATISTICS |
Match ID channel | Read only field - contains match ID channel name. Each item in this channel shows the indices of the items in the signature library associated with the match ID values. Script Parameter:UXAPERFORMSELFMATCH.MATCH_ID |
Cluster threshold | Specify the match threshold. Default value is 0.95. Script Parameter:UXAPERFORMSELFMATCH.TARGET_DATABASE_ID |
Above threshold channel | Specify the above threshold channel, which displays the number of matches above the threshold. Script Parameter:UXAPERFORMSELFMATCH.TARGET_DATABASE_ID |
Match Calculation Options | |
Min. polarizability amplitude | Specify the minimum polarizability amplitude, which is the lower bound of the polarizability values used in the classification. This value should be above or equal to zero. The default value is zero. Script Parameter:UXAPERFORMSELFMATCH.MIN_BETA_AMP |
Gates - Low | Select the low gate, which will affect the match statistic. Script Parameter:UXAPERFORMSELFMATCH.LOGATE |
Gates - High | Select the high gate, which will affect the match statistic. Script Parameter:UXAPERFORMSELFMATCH.HIGATE |
Criteria weights - Size | Specify the size. See the Application Notes below for more information. Script Parameter:UXAPERFORMSELFMATCH.WEIGHT_SIZE |
Criteria weights - Shape 1 | Specify the shape. See the Application Notes below for more information. Script Parameter:UXAPERFORMSELFMATCH.WEIGHT_SHAPE1 |
Criteria weights - Shape 2 | Specify the shape. See the Application Notes below for more information. Script Parameter:UXAPERFORMSELFMATCH.WEIGHT_SHAPE2 |
The self-match routine reads in a group containing polarizability data for sources and compares them to each other.
For each source in the group from the source database, the matching routine compares it to all the other sources and generates a match statistic. The match statistic for each of the three polarizabilities are combined in to a final single match statistic or metric based on the weighting using the following criteria:
- Size - the primary polarizability (β1),
- Shape 1 - the secondary polarizability normalized by primary polarizability (β2/β1), and
- Shape 2 - the tertiary or third polarizability normalized by primary polarizability (β3/β1).
By appropriately selecting the criteria weights, the match can based on 1, 2 or 3 of the polarizabilities. The match statistic ranges between 0 and 1, where 1 is a perfect match. This statistic and the matched source id description are each stored as array channels in the source database, labelled with the Match Channel Suffix.
The match criteria is computed at all time gates, expect where the values of a polarizability are below the minimum amplitude. If the polarizabilities used do not exceed the defined minimum amplitude, and the comparison cannot be performed, a metric of exactly zero (0) is returned.
Two or more sources with a match statistic greater than the cluster threshold are said to form a "cluster". The number of other or additional sources in the cluster is stored in the Above Threshold channel.
