Level Sensor Data
Use the Level Sensor Data option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaLevelData;Run)*) to subtract the background for the advanced sensors.
UX-Analyze extension:
  • AGC Static Data
  • AGG Dynamic Data > Drift and Background Removal
  • AGC Expert User > Static Data Prep and QC
  • AGC Expert User > Dynamic Data Prep and QC
Level Sensor Data dialog options
Survey database prefix
Specify the prefix for the survey databases (e.g., SAM, SFR).
Script Parameter:UXANALYZE.LEVEL_SURVEY_DBPREFIX
Group name
Select the group name.
Script Parameter:UXANALYZE.LEVEL_SURVEY_GROUP
Mask channel
Select the mask channel.
Script Parameter:UXANALYZE.LEVEL_SURVEY_MASKCHAN
Monostatic coil
Select the coil name from the list of X, Y, and Z. This selection determines which receiver coils data will be leveled.
This entry is enabled only when dynamic advanced data is being leveled.
Script Parameter:UXANALYZE.LEVEL_MONOSTATIC_COIL
Sensor channel suffix
Select the sensor channel suffix, which determines which data channels will be leveled.
This entry is enabled only when dynamic advanced data is being leveled. Default value is NORM.
Script Parameter:UXANALYZE.LEVEL_SENCHAN_SUFFIX
Sensor channel
Select the sensor channel.
This channel should exist in both anomaly chip and background databases.
This entry is enabled only when static (cued) advanced data is being leveled.
Script Parameter:UXANALYZE.LEVEL_RAWSENCHAN
Sensor channel suffix - leveled
Specify the sensor channel suffix, which will be added to the leveled data channel(s).
Script Parameter:UXANALYZE.LEVEL_LEVCHAN_SUFFIX
Sensor channel - leveled
This read-only field shows the name of the leveled sensor channel(s).
Background database prefix
Select the prefix for the background databases (e.g., SBG, SRB).
Script Parameter:UXANALYZE.LEVEL_BACKGROUND_DBPREIFX
Group name
Script Parameter:UXANALYZE.LEVEL_BACKGROUND_GROUP
Mask channel
Script Parameter:UXANALYZE.LEVEL_BACKGROUND_MASKCHAN
Background Selection Method
Background Selection Method determines the proper line/group in the background database for each line/group in the anomaly chip database.
  • Time & Location - When selected, the associated entries will be activated. If no grouping tolerance (m) is specified, the background with the closest time (hrs) within the threshold is picked.
    The default value for time threshold is 2.
    The default value for the grouping tolerance is 1.
    If the grouping tolerance (m) is entered:
    • The backgrounds within the time threshold are picked (set 1)
    • From all the backgrounds, the physically closest background to the target is found
    • From this background, all other backgrounds within the grouping tolerance are found (set 2)
    • From the set 2, the closest one in time will be picked
    • If there are no backgrounds within the time threshold the tool will issue a warning.
  • Time - The default time threshold is 2.
  • Location - When selected, the closest background to the anomaly data is selected from the background database.
Script Parameter:UXANALYZE.LEVEL_CALC_METHOD
As part of the acquisition procedure for cued and dynamic data collection with the advanced sensors, background measurements are recorded at different locations within the site and at various times. Background areas are identified as areas where there is no significant anomalous response above the noise envelop. The background data format is identical to that of anomaly data.
The background is subtracted from the anomaly data based on either location (closest background to target) or time (background with closest time), and background-removed data are saved as new channel(s) in the anomaly chip database and passed through to the inversion algorithms.
The background noise, or the difference between the closest background to the data and the closest background to the first one, is also saved as a new channel, UXA_Noise_Floor, in the anomaly chip database. Note that the UXA_Noise_Floor channel is only created when working in Static mode.
The background group/line ID, background database name and background line name are recorded in the site database under three channels, UXA_Background_ID, UXA_Background_Database and UXA_Background_Line. In case of static data, the location offset and the time offset between the background and measurement are also recorded in the target database under these channels: UXA_BACKGROUND_LOCATION_OFFSET and UXA_BACKGROUND_TIME_OFFSET.
The tool goes through all the non-masked survey lines, finds the closest group/line in the background database, and subtracts the background from the signal.
