Create Size and Decay Plot
Use the Create Size and Decay Plot option (Geosoft.uxo.gxnet.dll(Geosoft.GX.UXO.UxaSizeDecayPlot;Run)*) from the AGC Expert User > Source and Library Management menu to create a size/decay plot for Targets of Interest (TOI) in a source database.
Create Size and Decay Plot dialog options
Main Information
Targets only
When selected, targets within the specified threshold are plotted independently.
Script Parameter:UXANALYZE.CLUSTER
Targets with clusters
When selected, targets within the specified threshold are plotted in a cluster.
Source Database
Name
Specify the source database name.
Script Parameter:UXANALYZE.SOURCEGDB
Group
Select the source group.
Script Parameter:UXANALYZE.SOURCEGROUP
ID channel
Select the source ID channel.
Script Parameter:UXANALYZE.TARGETID
Mask channel
Select the source mask channel.
Script Parameter:UXANALYZE.TARGETMASK
Symbol mask channel
Select the symbol mask channel.
Script Parameter:UXANALYZE.TARGETSYMBMASK
Zone field channel
Select the source channel used to colour the data.
Use D button to define colour schema.
Script Parameter:UXANALYZE.TARGETCOLOR
Ground truth channel
Select the ground truth channel.
Ground truth channel contains 1, 0, and DUMMY values, which correspond to TOI, non TOI and no ground truth, respectively.
The targets with ground truth information will be displayed in full intensity colour while those without info will be 50% intensity.
When you select the Ground truth channel, you should also select the corresponding "Zone field channel". This channel is created as part of the "Set threshold and prioritize" option.
  • If you run this tool outside of the Process Data dialog, you should also ensure you are using the correct ITR file (C:\Program Files\Geosoft\Desktop Applications \etc\category.itr). If you run this inside the Process Data dialog, the proper Zone field channel and ITR file will be used.
  • The category value is read from the Zone field channel. If the category is less than or equal to 2, it is a "DIG"; otherwise, it is a "No DIG".
Script Parameter:UXANALYZE.TARGETGROUNDTRUTH
Size channel
Select the source size channel.
Script Parameter:UXANALYZE.TARGETSIZE
Size channel gate
Select gate for source size channel.
This combo box is populated with all the indices, starting at 0, up to the array length of the size channel.
Default value is dictated by the size of the array in the database, which indicates the sensor used. It is 8 for MetalMapper and 14 for TEM2x2x3.
Script Parameter:UXANALYZE.LOGATE
Decay channel
Select source decay channel.
Script Parameter:UXANALYZE.TARGETDECAY
Decay channel gate
Select gate for source decay channel.
This combo box is populated with all the indices, starting at 0, up to the array length of the decay channel.
Default value is dictated by the size of the array in the database, which indicates the sensor used. It is 36 for MetalMapper and 71 for TEM2x2x3.
Script Parameter:UXANALYZE.THRESHOLDGATE
Match channel suffix
Specify the match channel suffix.
Channel suffix will be added to "UXA_LmStat_" and "UXA_LmID_" prefixes to create match statistics and match ID channel names.
Script Parameter:UXANALYZE.LM_SUFFIX
Match statistics channel
Read only field - contains match statistics channel name.
Match statistics metric shows the degree of match between a target and the items in the signature library, so its size would be the same as the number of items in the signature library.
Match ID channel
Read only field - contains match ID channel name.
Each item in this channel shows the indices of the items in the signature library associated with the match ID values.
Match threshold
Specify the match threshold. Default value is 0.95.
Script Parameter:UXANALYZE.MATCH_THRESHOLD
Output Plot
Plot prefix
Plot prefix is combined with the target IDs to create the plot name: Prefix_target ID.png.
Script Parameter: UXANALYZE.MAPPREFIX
Plot name
This field shows the complete plot name.
The folder to save the scatter plots is: UXANALYZE_wrk\scatter_plots\Prefix_image.
Extents
Specify minimum and/or maximum extents for size and/or decay data. Click on buttons beside text boxes to automatically populate extents from current data.
Script Parameter:UXANALYZE.OVERLAY_NAME
Minimum size extent
Specify minimum extent for size data.
Use Calculate button to automatically calculate the value.
Script Parameter:UXANALYZE.MINSIZE
Maximum size extent
Specify maximum extent for size data.
Script Parameter:UXANALYZE.MAXSIZE
Minimum decay extent
Specify minimum extent for decay data.
Script Parameter:UXANALYZE.MINDECAY
Maximum decay extent
Specify maximum extent for decay data.
Script Parameter:UXANALYZE.MAXDECAY
Symbol attributes - symbol
Select symbol type to represent points on the plot.
Script Parameter:UXANALYZE.SYMBOLTYPE
Symbol attributes - size
Specify symbol size.
Script Parameter:UXANALYZE.SYMBOLSIZE
Symbol attributes - colour
Select symbol colour.
Script Parameter:UXANALYZE.SYMBOLCOLOR
Library overlay name
Select a library overlay name. The library overlay files are saved in your "%USERPROFILE%\Documents\Geosoft\Desktop Applications \etc" folder.
Script Parameter:UXANALYZE.OVERLAYNAME
As of Oasis montaj version 8.3 the Create Size and Decay Plot option uses a new drawing engine, in addition to the original method, to speed up the plot generation. The following is how the Create Size and Decay Plot option determines which method to use:
  • Old method: when a library overlay is selected, which does not have the new (*.uxa_overlay) file, you will receive a warning.
    • No legend will be plotted with the old method.
  • New method: when either no library overlay is selected, or the selected overlay has an (*.uxa_overlay) file, no *.map file will be generated.
    • A legend will be plotted with the new method.
