Add/Modify Data IP (2/3) - Measurements
The same tool is used to add data to VOXI the first time and to subsequently modify it.
Use Data > Add Data on the VOXI Manager tree to set the type of inversion and provide the data channels for the geophysical modelling.
Subsequently, to modify the data of an existing VOXI document, use Data > Data Source > Modify.
Measurements dialog options
Type of system |
You can invert both Conductivity/Resistivity and IP and Spectral IP data. Select the appropriate system based on the database supplied in the previous dialog. |
Type of model |
The model types are a function of the IP system specified above and in the first dialog. The model type selection list is contextual and is populated dynamically. The supported model types for the Conductivity/Resistivity and IP system are:
You must first invert the data to obtain a conductivity or resistivity model in order to be able to proceed and invert for a chargeability model.
The supported model types for the Spectral IP system are:
The Complex conductivity/resistivity option inverts both the amplitude and phase models. These can also be modelled separately.
Field data |
This is a contextual parameter subject to the type of system and model. You will be prompted for the data necessary to invert the selected model(s). You will not be able to proceed until you have provided all the necessary information.
If you are modelling:
If you select:
IP type |
This parameter is contextual and appears if you have selected Chargeability as the model type. Different types of data can be used to model chargeability, all of which are mathematically interrelated. Specify the nature of the field data you have supplied for the inversion process. |
Mask channel |
Prior to modelling, the data must be QAQC’d. During the QAQC stage, some data values are flagged for exclusion. Good points are flagged as "1" and bad points as dummies. This information is stored in a channel. Select the Mask channel to exclude the bad data from being used in the inversion process. | ||||||||
Fit error |
VOXI will attempt to fit your data until the difference between the model prediction (the fit) and the measured data is on average less than the fit error. Increasing the fit error focuses the inversion on features of a larger magnitude at the expense of overlooking the small variations, while decreasing the fit error focuses on the subtler features and enhances the structure. Four Fit error methods are available. After you select the type, the dialog will adjust to prompt you for the related parameters as described below.
The VOXI inversion process - subject to the constraints provided - will attempt to completely explain the measurements through the physical parameters of the model.
To learn more about effective workflows and key concepts, access the
