Vector Voxel to GDB
Use the Vector Voxel To GDB GX to export a vector voxel to a database (Geosoft GDB).
Vector Voxel to GDB dialog options
Input vector voxel |
Select the vector voxel file to be exported to a database, either from the dropdown list or the browse dialog. Script Parameter: EXPDBVECVOX.VOXEL |
Output database |
Enter or browse for the output database file. By default, the output database is given the same name as the input vector voxel. Script Parameter: EXPDBVECVOX.DATABASE |
Data channel prefix: |
If entered, all output data channels (see notes) are prefixed with this string, followed by an underscore. By default, no prefix will be prepended to the output channels. Script Parameter: EXPDBVECVOX.PREFIX |
Direction |
Specify the direction axis (X, Y, or Z) along which the voxel will be exported. Script Parameter: EXPDBVECVOX.DIRECTION [0: X, 1: Y, 2: Z] |
Output dummies |
If checked (default), dummy voxel elements will be omitted from the output database. Script Parameter: EXPDBVECVOX.DUMMY [0-No, 1 – Yes] |
In addition to the XYZ location channels, the following channels are saved:
Amp, Inc, Dec: The amplitude, inclination and declination of the vectors. The Amp channel is displayed to a number of decimals that is determined from the largest amplitude value, so that it will give 4 significant digits.
VX, VY, VZ: These are the magnitudes of the components ("V" for "Value") in the X, Y and Z directions. They are displayed to a number of decimals that is determined from the largest amplitude value, so that it will give 4 significant digits.
DX, DY, DZ: These are the normalized components, equal to VX/Amp, VY/Amp and VZ/Amp. These are always in the range -1.0 to 1.0, and are displayed with 3 decimals.
Direction:
The first coordinate in the direction designation indicates the slice plane, the data along the 3rd coordinate changes faster than the 2nd one. For example, in the designation YXZ, an entire slice in the Y plane will be saved as a database line. In each line, consecutive points are ordered along the Z direction, followed by the Y direction.
