Help for Leapfrog Viewer 2025.2
The Leapfrog Viewer is a 3D viewer for scenes exported from Leapfrog applications in the proprietary Leapfrog Scene format. With Leapfrog Viewer 2025.2, you can view *.lfview files.
Leapfrog Viewer 2025.2 does not open *.scene files. To view files in *.scene format, download Leapfrog Viewer 4.15.
To run Leapfrog Viewer, launch Leapfrog and then sign in using either your Seequent ID credentials or your Bentley account credentials. As part of the sign-in process, you will be prompted to choose to work in Leapfrog Viewer.
Signing In with a Seequent ID
If you are signing in using a Seequent ID, choose your own name as the Organisation. This selects the Leapfrog Viewer product:
Signing In with a Bentley Account
If you are signing in using a Bentley account, there are two possibilities.
The first is similar to signing in using a Seequent ID, where you choose your own name as the Organisation:
The second is that Leapfrog Viewer is one of the products available:
Whichever the case, click Get Started to open Leapfrog Viewer.
You can learn more about using Leapfrog Viewer in the Leapfrog Viewer help, which you can open from the menu in the upper left-hand corner of the main window:
