Selecting Intervals
When you wish to select a small portion of intervals or you don’t have suitable parameters to use a query filter, you can select intervals from boreholes displayed in the scene to create a new lithology column. The original lithology column is preserved and a new lithology column is added to the interval table. You can then select the original lithology column or the new one when displaying data and creating models.
To start selecting intervals, first add the drilling data to the scene. Then right-click on the interval table in the project tree and select New Column > Interval Selection. For a merged table, right-click on it and select Interval Selection.
The New Lithology Column window will appear:
The Interval Selection window will appear, together with a set of tools that will help you to select intervals in the scene. To select intervals, click on the Select Intervals button (
You can also:
) or by pressing Ctrl+I.
To change the width of the line used to select intervals, click on the Change line width button (
When you delete a lithology from the list, all intervals that have been assign to that lithology will revert to the lithology assigned in the Base Column.
) and close the Interval Selection window. The new lithology column will appear in the project tree as an additional lithology column in the interval table. Select the new column from the shape list to display it:
