Flow Models
Geological models created in Leapfrog Works can be used as the basis for MODFLOW and FEFLOW models. You can create flow models directly in Leapfrog Works and assign hydrological/material properties based on the lithologies in the geological model. Flow models can be exported for use in other applications, and you can import existing flow models and use them as the basis for the construction of new models. Flow models can be displayed in the scene, and time-dependent data can also be visualised.
Working with MODFLOW and FEFLOW models is available with the Hydrogeology extension. Contact Customer Support as described in Getting Support for more information about the Hydrogeology extension.
If when you open a project you get a message saying that the project contains restricted objects, this is because one or more objects were creating using Leapfrog Works features available in an extension you did not sign in with. Click Show restricted objects to view the affected objects. See Restricted Objects in The Project Tree topic for more information.
All tools for building flow models are accessed by right-clicking on the Flow Models folder and the objects in it. Imported objects and objects created while building a flow model are also stored in the Flow Models folder, and more complex functions can be carried out by right-clicking on individual objects.
