This topic is divided into:
- Adding and Styling Models
- Adding and Styling Boreholes and Planned Boreholes
- Adding and Styling Surfaces
- Adding and Styling Lines
- Adding and Styling Points
The folders below the Section object are used to add and organise models, boreholes, surfaces, lines, points and structural data and to customise how they are displayed:
- For the Boreholes folder, there are two options, Add Boreholes and Add Planned Boreholes. For both options, you can choose from the boreholes and planned boreholes available in the project.
It is not necessary to evaluate objects in the project on the section before working in the section layout editor. When you add an object to the layout, Leapfrog Works will automatically evaluate it on the section.
Models, boreholes, surfaces, lines, points and structural data occupy the same space on the section layout, and opacity settings and an object’s position among the layers can be used changed to emphasise relevant information. To change the order of objects on the page, right-click on them and select an option:
- For geological models, numeric models and combined models, expand the model in the layout tree to change how each output volume is displayed. You can also hide or highlight some of the output volumes. The fill colour and hatching options for each can also be customised.
It can result in a large number of surfaces to work with, but does provide you more control over how these surfaces appear on the section layout. For example, here the outline of the GnD volume can be shown in different styles (as with the D2 contact) or not at all (as with the Dike contacts):
You could alternatively display a contact surface on a section layout as a surface evaluation, but you can have only one line style and you don’t have control over what parts of the surface are displayed. For example, you cannot hide the surface where it is intersected by the dike:
- For category evaluations, you can change what categories are visible and the colours used to display them.
For example, here, a MODFLOW model is displayed using the Colouring from an evaluated geological model:
The colours used to display categories cannot be changed in the Block Colouring Legend as they are the colours used by the evaluated model itself. You can, however, hide some categories so they are not displayed on the section layout.
Here, the MODFLOW model is displayed using the Colouring from a hydrological evaluation:
The Boreholes folder contains all boreholes and planned boreholes that have been added to the section layout. To add boreholes to the section, right-click on the Boreholes object and select either Add Boreholes or Add Planned Boreholes.
When adding a borehole projection, you will be prompted for the interval tables to display; more than one can be selected. Each table will be added as a separate item below the Boreholes folder.
When you click OK the borehole is added to the layout tree. It will be flagged with No Selection.
Select the new borehole and double-click it to open a window to select boreholes. Use the filtering options to determine the limits for the projection of the boreholes onto the section based on the minimum distance from any point on the borehole trace to the section plane, and select from the filtered list of boreholes which should be projected.
When adding planned boreholes, you can select from the available planned borehole drilling phases, or select all phases. Then use the filtering options to determine the limits for the projection of the boreholes onto the section based on the minimum distance from any point on the borehole trace to the section plane, and select from the filtered list of boreholes which should be projected.
For both the borehole and planned borehole projections, the borehole selection window offers the option to Clip geometry to filter distance. With this selected, only the parts of boreholes that are within the specified minimum distance will be projected onto the section.
With Clip geometry to filter distance unchecked, if part of a borehole is within the minimum distance specified, the whole borehole will be projected onto the section.
When boreholes and planned boreholes are added to a curved section, a projection is made based on the locations of neighbouring segments of the section, using the bisectors of the angles between each segment and its neighbour. These determine the projection point of origin for a given segment of the section. When boreholes are filtered by the distance to the section plane, the distance is measured at 90 degrees from the section. Some boreholes may report a distance that is greater than the specified minimum distance; if this is the case, it is because the evaluation distance is relative to the projection origin. On the inside of a tight corner, a single borehole may be projected multiple times onto the section. If this is the case, the multiple instances of the borehole will appear in the boreholes list and you can turn individual instances off, if required.
When a long section is updated, borehole evaluations are updated. If there are multiple instances of a borehole evaluation, how they appear on the section may change when the section is updated:
- If all instances of a borehole evaluation have been enabled, then all remain enabled when the section is updated.
- If all instances of a borehole evaluation have been disabled, then all will remain disabled when the section is updated.
- If only some instances of a borehole evaluation have been enabled, then all instances will be enabled when the section is updated.
When a section layout is copied to another section from a long section, borehole evaluations will not be copied with the section layout.
Select an item under the Boreholes in the layout tree to see the properties to make the objects visible and to change their opacity and line width.
If you select an object with existing drilling data, you will have additional options. Up to three columns of data can be displayed as stripes down the borehole, and numeric data can even be displayed as a graph. Tick either the Left, Centre or Right positions for the boreholes to enable the visualisation and assign a Colouring according to an interval data selection.
Next to each Colouring, the Options button opens a properties dialog for customisation for each set of interval data. The Line width can be set for each stripe down the borehole.
For numeric data, a Value filter can be used to restrict the range of data shown in the borehole stripe.
- Bar graph which adds a variable width up to create a bar graph running down the borehole with downhole sample values being indicated by the Colourmap colouring:
The bar and line graph options are not available for the centre of the borehole, although the solid option can be used.
Bar graph and Line graph extend out from the borehole to a specified Max length. Select a Max length that means that displayed data does not interfere with other boreholes or data displayed on the section layout.
This is especially relevant when two graphs are displayed per borehole.
The Axis limit fields clip the chart range to the minimum and maximum values of interest and an option is provided to make the value axis scale a Logarithmic scale. The line graph option provides the ability to specify the Colour of the line. Click the colour tile and select a new colour using the colour picker.
Both category and numeric data Options windows also have a Labels tab. Labels can be shown or hidden using the Show labels tickbox abd the Text style can be selected from one of the text styles provided and modified using the Edit styles button. The Offset specifies the distance from the borehole the label will appear. Numeric data labels also add the option of making this offset a Constant distance or adding the Numeric value to the Offset to stagger the labelling according to the data values. The Rotation of the label can be specified so they appear at a tilted angle from the borehole, and this angle can be specified to be with reference to the Horizontal if the labels should all be parallel, or Perpendicular to trace if the labels should follow the curve of the borehole. Numeric labels also have the option to specify the number of Decimal places in the labels.
Labelling numeric data values works best for numeric data sets with sparse data sampling because when data samples are close together it can lead to cluttered and overlapping labelling, even when reducing the size of the font used for labelling.
Besides the labels associated with interval data described above, you can also have the following type of labels at different points along the borehole trace:
- Top labels
- Intercept labels
- Bottom labels
- Depth markers
- Collar points
- Intercept points
- Depth markers
An intercept point is where the borehole intersects the section plane.
Select either a borehole object or planned borehole from the Boreholes folder in the layer tree, then select the Points and labels tab.
Top, bottom and intercept labels can have the Text style selected from the available styles, or you can click Edit Styles to customise the style. Offset (x, y) positions the label a specified distance away from the point it is referencing. Rotation will put an angle on the label, useful when labels are close together. Top and bottom labels have the option to Show minimum distances for the borehole from the section plane. You can also choose to Show units and specify the number of Decimal places to show. Labels can have a line connecting them to the point they refer to, if Draw label lines is ticked and once the label is more than the At offset length away from the point. The Line style. Line width, Pattern scale and colour can be customised. A Preview shows what the line will look like on the section.
Depth markers display ticks down the length of boreholes with optional distance labels. On the Ticks tab, the tick Spacing can be specified, and you can choose to optionally Display tick at base of borehole. The Orientation of the tick can be Horizontal to display all the ticks in parallel, or Perpendicular to trace to have the tick orientation follow the curve of the boreholes. The Side of the borehole centreline the tick extends from can be specified as Left or Right. The Line length specifies how far from the borehole centreline the tick extends, and the Line width determines how thick the tick is.
On the depth marker Labels tab, the labels can be enabled using the Show labels tickbox and customised in the same way as other labels using the Text style selector and the Edit Styles button. Offset (x, y) positions the label a specified distance away from the tick it is referencing. Rotation will put an angle on the label. You can also choose to Show units and specify the number of Decimal places to show. Labels can have a line connecting them to the point they refer to, if Draw label lines is ticked. The Line style. Line width, Pattern scale and colour can be customised. A Preview shows what the line will look like on the section. Depth marker labels can be selected and dragged into a new position to avoid overlapping with adjacent items on the section. Click the Reset Dragged Labels button to restore them to the default position.
The Lines folder contains all lines that have been added to the section layout. To add another line, first make sure it has been evaluated on the section, then right-click on the Lines folder and select Add Line. Select from those available and click OK.
Click on the line in the layout tree to view line styling options. Visibility can be turned on or off and the Opacity of the projection of the line onto the section can be set. Edit the text used to display the line by enabling the Edit box and then changing the text. You can change the Line style, Line width, Pattern scale and colour. You can also define a marker to display along the line by enabling Add marker and then specifying a Symbol to use. Increasing the Occurrence number increases the gap between symbols. A Preview is displayed and the surface will be updated in the section preview.
Under Colourings you can also select between a Flat colour option that can be selected and changed in the Colouring Options window by clicking the colour tile and using the colour picker, or you can choose Layer colour to use the same line colour used in the scene and modified using the colour selector in the shape list.
You can select multiple lines by holding down the Shift key or the Ctrl key while clicking. You can then style the selected lines similarly without having to make individual customisations to each line.
The Points folder contains all points objects that have been added to the section layout. To add another points object, right-click on the Points folder and select Add Points. Select from those available and click OK.
You can choose to Show labels or hide them. From the selector you can choose the same option as used for Colourings or a different option. Click the Options button to customise the labelling. Text style provides a list of available styles, or you can click Edit Styles to customise the style. Offset (x, y) positions the label a specified distance away from the point it is referencing. Rotation will put an angle on the label, useful when labels are close together. You can choose whether or not to Show minimum distances for the borehole from the section plane and you can also choose to Show units and specify the number of Decimal places to show. Labels can have a line connecting them to the point they refer to, if Draw label lines is ticked and once the label is more than the At offset length away from the point. The Line style. Line width, Pattern scale and colour can be customised. A Preview shows what the line will look like on the section.
Click the Options button to customise the labelling. Text style provides a list of available styles, or you can click Edit Styles to customise the style. Offset (x, y) positions the label a specified distance away from the point it is referencing. Rotation will put an angle on the label, useful when labels are close together. The Decimal places setting under the Labels heading sets how many decimal places are shown in the label value. You can choose whether or not to Show minimum distances for the borehole from the section plane and you can also choose to Show units. The Decimal places setting under the Distances heading sets how many decimal places are shown in the minimum distance value. Labels can have a line connecting them to the structural data they refer to, if Draw label lines is ticked and once the label is more than the At offset length away from the structural data. The Line style. Line width, Pattern scale and colour can be customised. A Preview shows what the line will look like on the section.
