The 3D Scene
This topic describes how to interact with the 3D scene. It is divided into:
How to change the way objects are displayed in the scene is described in detail in the Visualising Data topic.
The slicer is a powerful tool for revealing data that is concealed behind other objects and for emphasising data; it is described in a separate topic, Slicing Through Data in the Scene.
Navigating in the Scene
The best way to navigate the 3D scene in Leapfrog Works is using the mouse. If you are running Leapfrog Works on a laptop, it is recommended that you plug in a mouse rather than using the laptop’s touchpad for navigation. However, you can also navigate in the scene using the keyboard.
Action
Mouse
Keyboard
Changing the viewing angle
Click and drag to rotate the scene
Press the arrow keys to rotate the scene
For smaller steps, hold down the Shift key while pressing the arrow keys
Zooming in and out of the scene
Use the scroll wheel
Hold the right mouse button while moving the mouse
Press the Page Up or Page Down keys
For smaller steps, hold down the Shift key while pressing the Page Up or Page Down keys
Panning the scene
Click and hold both mouse buttons, then drag
Hold the scroll wheel and drag
Hold down the Alt key while pressing the arrow keys
Centre an object in the scene
Click the scroll wheel
Click both mouse buttons together
Use the Look menu above the scene window to switch to different viewing angles:
The Look menu above the scene window, open to show the preset viewing directions, projection modes and bookmark commands with their keyboard shortcuts.
If you prefer to navigate using the keyboard, use the following keyboard shortcuts:
Key(s) Action
Arrow keys Rotate the scene in 10 degree steps
Shift+Arrow keys Rotate the scene in 2 degree steps
Home Reset the view, showing all visible objects in scene
U, D, E, W, N, S Look Up, Down, East, West, North and South
L Look at the slicing plane
Shift+L Look at the back of the slicing plane
M Look at the moving plane
Shift+M Look at the back of the moving plane
Ctrl+M Look down the moving plane pitch
Shift+Ctrl+M Look up the moving plane pitch
P Select Perspective view
O Select Orthographic view
Ctrl+Delete Clear the scene
Ctrl+B Bookmark the viewing angle and zoom
B Display the bookmarked viewing angle and zoom
Ctrl+’ Save the scene
Ctrl+C Copies the scene to the clipboard. The image can then be pasted into another application, such as an image editor.
Ctrl+/ Add the slicer to the scene. Press Ctrl+/ to remove the slicer from the scene.
Ctrl+; Add the moving plane to the scene. Press Ctrl+; to remove the moving plane from the scene.
The current viewing angle and scale are displayed in the lower right-hand corner of the scene window:
The viewing angle and scale readout in the lower-right corner of the scene window, showing plunge, azimuth, an orientation ball and a scale bar.
You can change how the viewing angle and scale are displayed in the Overlays tab of the Settings window.
You can save the current viewing angle as a bookmark by selecting Bookmark Viewing Angle from the Look menu or by pressing Ctrl+B. Restore the bookmark by selecting Look > Restore Bookmark or by pressing B.
Only one viewing angle bookmark can be saved. The bookmark is not saved when Leapfrog Works is shut down.
The scene window displays a 3D representation of selected data from the project tree. You can add objects from the project tree to the scene in two ways:
  • Click on the object and drag it into the scene. Hold down the Shift key or the Ctrl key while clicking to select multiple items, then add them to the scene.
  • Right-click on the object and tick the View Object box.
Dragging objects into the scene window may be blocked by other applications on your computer. For example, if you are sharing a screen using Skype, you will not be able to drag objects into the scene.
Once you have added objects to the scene window, you can change the appearance of those objects using the controls in the shape list and the shape properties panel.
The Scene View with the shape list and shape properties panel highlighted beneath the scene, which is where the appearance of objects in the scene is controlled.
This is described in detail in the Visualising Data topic.
Changing how you view objects in the 3D scene does not change those objects in the project tree.
All objects in the shape list have a button () (A) that will remove the object from the scene. Most objects also have a visibility button () (B) that can temporarily hide that object in the scene. It is often easier to make an object temporarily invisible than to remove it from the list. Some objects have an edit button () (C) that you can click to begin editing the object.
The shape list with the remove button marked A, the visibility buttons marked B, and the edit button marked C.
Viewing Object Details
Clicking on an object in the scene displays a Scene Details panel that contains a summary of the data. For example, here drilling data is displayed in the scene and clicking on a segment displays information about the selected segment. For drilling data, this information includes the hole ID for the selected segment, location information for the interval, the Downhole depth at the selected location and the values for the different data columns in the table:
The Scene Details panel for a clicked drillhole interval, showing hole ID, interval, downhole depth and column values, with the displayed column shown in bold.
The column used to display the data is shown in the list in bold text, as is the case for the RockType column above.
You can change which columns and evaluations are displayed in the list by clicking on the Edit Details button () and selecting which items you want displayed:
The Edit Details Filter window opened from the Scene Details panel, with two of the four columns ticked and the panel below showing only those columns.
You can keep the Edit Details Filter window open while adding and removing items.
Once you have selected a subset of details, toggle between them using the filter button ():
The filter button in the Scene Details panel title row, used to toggle between the filtered subset of columns and the full list.
The width of the scene details panel can be resized, revealing long labels or values.
  • By default, the relative column size ratio is preserved when adjusting the scene details panel width.
  • You can adjust the label column width independently, and once you have selected a label column width, that preference is preserved.
  • To return to the default column width ratio that adjusts both columns when the scene details panel is adjusted, right-click on the panel and select Reset Column Widths.
  • When column width adjustments are insufficient to reveal an entire label or value, click on the expand/collapse chevron to reveal the entire label or value, wrapped to multiple lines within the current column width. If the row is for an object with child rows, these will also expand.
If all rows are collapsed, you can double-click on the column separator to get a minimum-width label column.
You can copy information from the scene details panel by right-clicking on a row and selecting Copy. The scene details header, containing the name of the object selected in the scene, along with the row label and value, will be copied to the clipboard ready for pasting elsewhere. Alternatively, you can select Copy Header from the menu, and only the selected object name will be copied to the clipboard. If you wish to only copy the row label or value, double-click on the information you want to copy to the clipboard, then right-click on the selection and select Copy.
From the panel, you can also add comments to the object.
Different objects will display different information in the scene details panel. Here information about a surface is displayed, including the volume, area, number of parts and whether or not the mesh is open or closed:
The Scene Details panel for a clicked surface, listing location, volume, area, parts, face dip and dip azimuth, and reporting that the mesh is not closed.
Many objects have an Open option you can click on to do further work on the object. For drilling data tables, for example, doing this will open the table. For contact surfaces, as shown here, doing this will open the surface’s Edit dialog:
The Open link in the Scene Details panel for a contact surface, and the Edit window it opens for that surface.
Some objects will also include options for working with the object by, for example, editing the object’s attributes or using the moving plane to set direction attributes. For example, here information is displayed for a geological model and there is a link to editing the model’s attributes:
The Edit Attributes link in the Scene Details panel for a geological model, and the Attribute Table it opens showing dip, dip azimuth and pitch per volume.
You can display the Scene Details panel docked to the scene or floating. In the examples above, the panel is docked. To float the window, click and hold on its upper edge and drag it. The window will pop out and you can position it where you wish.
To dock the panel, drag it into the lower lefthand corner of the scene until the panel turns transparent. When you release the mouse button, the panel will dock.
You can use keyboard shortcuts to navigate the scene details panel, like you would navigate the project tree.
Key(s) Action
Up and down arrows Navigate up and down the object details list
Right arrow or Shift + Right arrow Expand collapsed row
Left arrow or Shift + Left arrow Collapse expanded row
Ctrl+shift+right arrow Expand all collapsed rows
Ctrl+shift+left arrow Close all expanded rows
Locating an Object from the Scene
When you have a number of objects displayed in the scene, it may not be readily apparent where you can find more information about those objects. The fastest way to locate the object in the project tree is to:
  1. Click on the object in the scene.
  2. This selects the object in the shape list.
  3. Right-click on the object in the shape list.
  4. Select the Go to Project Tree option.
Measuring in the Scene
Leapfrog Works has a number of tools for making quantitative measurements in the scene. These include:
  • Clicking on an object in the scene. This will open a window containing more information about the object.
  • Viewing an object’s properties to determine its size. Right-click on the object in the project tree and select Properties. Information on the size of the object will be displayed in the General tab.
  • Using the cursor to determine an approximate location in the scene. See Determining a Location.
  • Using the moving plane to measure trends. See The Moving Plane.
  • Using the ruler to measure in the scene. See The Ruler.
  • Calculating a distance measured. See The Distance Calculator.
The simplest way of measuring an approximate location in the scene is to first display an object in the scene window, then position the cursor over the location. The position of the cursor is displayed at the bottom of the Leapfrog Works window:
The approximate position of the cursor in the scene, shown as three coordinates in the status bar at the bottom of the window.
The position of the cursor in the scene is calculated using the depth buffer on the graphics card and so is not an exact method of measuring in the scene.
If you require an exact position, click on the object. Leapfrog Works will compute the exact position of the point highlighted in the scene and display it in a pop-up window:
The exact position of a clicked point, computed and shown to four decimal places in a pop-up panel, alongside the surface's face dip, area and parts.
The Moving Plane
In Leapfrog Works, the moving plane is used for measuring planar structures and defining coordinate system orientations. There are two tools in the toolbar that relate to the moving plane:
The moving plane in the scene with its coloured drag handles, the two toolbar buttons that control it, its shape list row showing dip, dip azimuth and pitch, and the Axes option for aligning the movement handles.
To use the moving plane, click the Show plane button () and position the plane in the scene. The main axis of the moving plane is defined by the green line. The second axis is defined to be in the plane at right angles (orthogonal) to the main axis. Third axis is perpendicular to the plane.
There are three ways to position the plane. You can:
  • Use the handles in the scene window to move the plane. If you cannot see the handles, click on the moving plane.
  • Use the Plane controls in the shape properties panel to change the Dip, Dip Azimuth, Pitch and Centre Point.
  • Orient the scene to look parallel to the required plane position, then click on the Draw plane line button (). Draw the required line in the scene.
Plane movement can be aligned to the Axes or to the Camera:
  • With the Axes option, the handles move in cartesian coordinates. .
  • With the Camera option, the handles move relative to the camera angle.
Drawing the plane line is usually the most convenient method of defining a planar structure.
To remove the moving plane from the scene:
  • Click the Show plane button ().
  • In the shape list, click the delete button () for the moving plane.
Use the following keyboard shortcuts to control the moving plane:
Key(s) Action
The Ruler
You can use the ruler to measure distances in three dimensional space and between boreholes and planned boreholes.
The easiest way to use the ruler is to click on the Ruler button () and click and drag between points in the scene to start making measurements. A ruler line will appear in the scene to indicate the measurement. Information about the distance measured will appear in the scene and in the shape properties panel:
A ruler measurement drawn between two points in the scene, with the distance shown beside the ruler line, in the shape list row and in the shape properties panel alongside plunge and azimuth.
The ruler tool stays active in the scene so you can make as many measurements as required.
There are two ways to remove the ruler from the scene:
  • Click the Select button ().
  • Click the delete button () for the ruler object in the shape list.
You can also calculate the measurement of the shortest distance between objects, boreholes, points or a combination or any of the three. For example, use the distance calculator when you have a planned borehole and would like to know how close it is to an existing underground mine development.
To do this, add the ruler to the scene, then click on the Calculate Distance button in the shape properties panel. The Distance Calculator window will appear:
The Distance Calculator opened from the shape properties panel, set to measure the shortest distance between two named drillholes, with the result shown as 96.90.
Select which two items to measure between. Options are:
  • An object, which will measure from the closest object in the selected table.
  • A hole. Start typing a hole number to display a list of options to choose from.
  • A point, which can be selected in the scene by clicking the Select button () in the Distance Calculator window, then clicking in the scene.
Click Calculate. The Distance will appear in the Distance Calculator window. The Start, End and Difference of your selections will appear in the shape properties panel.
Click Zoom to zoom to the ruler in the scene.
After measuring a distance, it is a good idea to change the viewing angle to confirm that the measurement has been made between the correct points in three dimensions.
Working With Split Views
The Split View button () in the toolbar allows you to view up to two alternative views of the objects displayed in the scene:
The Split View button in the toolbar, opened to show the options for splitting the scene into two or three panes vertically or horizontally.
The alternative views available are a Plan View or a Zoomed Out view:
The scene split into a main view and two alternative views, with one view's dropdown open to show the two choices, Plan View and Zoomed Out.
You can also open an alternative view in a new tab by choosing the New Split View Tab option:
The New Split View Tab option selected at the bottom of the Split View menu, which opens an alternative view in its own tab.
You can resize the scene and the alternative views and Leapfrog Works will remember the position of each view when you switch to that split view again.
To return to displaying only the scene view, click the Split View button ().
Each alternative view has a toolbar that gives you different options for displaying the view. Use the Enclose Object list to zoom into or out of the alternative view:
The Enclose Object list for an alternative view, opened to show the current setting at the top followed by the clipping boundary and the objects in the project that the view can zoom to.
The list displayed includes all objects available in the project, plus the clipping boundary and the current scene view.
Click the Visibility button to change what objects from the scene view are visible in the alternative view:
The Visibility window for an alternative view, listing the objects from the scene view whose visibility can be controlled separately in that view.
An object must be visible in the scene view’s shape list for its visibility to be controllable from the alternative view’s Edit Visibility list. What this means is that objects hidden in the scene view cannot be made visible in an alternative view.
When the slicer is in the main scene view, you can display the contents of the alternative view sliced or unsliced. Click the View Unsliced button (). The slicer, shown in blue in this image, remains displayed in the alternative views, but the view’s contents are displayed unsliced:
The View Unsliced button turned on for an alternative view, so its contents are drawn unsliced while the blue slicer outline is still shown in the alternate views.
In alternative views, you can display a view window that shows what part of the alternative view is displayed in the scene view. Click the Enable View Window button ():
The Enable View Window button turned on for the alternative views, which draws an outline on each showing the area currently displayed in the main scene view.
Each alternative view has a Settings button () that lets you change what overlays are displayed for that view. The alternative view can use the scene view settings, or you can customise the display of the screen grid, axis lines and scale bar:
The Split Scene Settings window for an alternative view, with controls for the screen grid spacing, axis lines and scale bar shown in that view.
