Defining Calculations and Filters
Some aspects of this feature may be illustrated using examples including block models. Block models are a feature that requires the Contaminant extension in Leapfrog Works. What is described for points objects can also be applied to block models if you have the Contaminants extension.
Many data tables support calculating new data values based on existing data. This is achieved via the Calculations window, which in some cases is also combined with defining filters.
This topic describes how to define calculations and filters. It is divided into:
The topic that follows, Catalogue of Metadata, Syntax and Functions, details each of the items in the pinnable Insert list and includes intentionally trivial examples to illustrate the use of the item, along with an explanation of the effect of the expression.
The Calculations Window
Right-click on a data table in the project tree and select either Calculations or Calculations and Filters. The option will differ dependent on the data table type. The examples below show the Calculations window for drilling data tables; not all options will be available for other types of tables.
Right-clicking a data table and choosing Calculations and Filters
When the Calculations window is first opened, the Insert list is pinned to the right-hand side. You can untick the Pin Window box to get more screen space.
The Calculations window as first opened, with the Insert reference panel pinned to the right
You can then select items by clicking on the Insert menu.
With the window unpinned, the same reference lists drop down from the Insert button instead
Items in this list are divided into Existing items and Syntax and functions. Existing items include handy metadata items you can use immediately, e.g. row ID and point location coordinates. It also includes evaluations that can be selected, such as estimators. Syntax and functions contains mathematical operators and other calculation elements, along with special values such as 'blank' and 'error' and pre-made functions such as unit conversions and log(n).
If the Calculations window is docked as a tab, you can tear the tab off to form a stand-alone window. You might do this when arranging your windows so you can see the Calculations window at the same time as the scene. The detached window can be docked again by dragging the tab back alongside the other tabs, as described in Organising Your Screen Space.
The arrow buttons allow you to quickly expand () or collapse () all calculations and filters. You can also individually expand or collapse a calculation or filter by clicking on the = symbol next to the calculation or filter name.
Cut(), Copy() and Paste() buttons provide basic text operations on selected parts of equations.
Undo() and Redo() buttons provide the ability to move back and forward in the edit history for your equations.
Copying, Importing and Exporting Calculations and Filters
The toolbar in the Calculations window has three buttons that relate to copying, importing and exporting calculations and filters between points objects and projects:
The copy-from, import and export buttons in the Calculations window toolbar
To copy calculations and filters from another points object, click the Copy items from another object button () and select the source to copy from.
To export calculations and filters, click the Export button (). You will be prompted for a file name and location. The information is saved in *.lfcalc format, which is a binary file format. This format cannot be read or written by any other program.
To import calculations, click on the Import button () and select a calculations file to import.
Creating a New Calculation or Filter
Click the Create a new item button () to add a calculation to the Calculations window.
The New Item window, offering a variable, numeric calculation, category calculation, RGB to hex colour or filter
Not all these options may be available, depending on the type of object calculations are being defined for.
The New Item windows gives you the choice of creating a variable, a numeric calculation, a category calculation, an RGB to hex colour or a filter. Select one of these options, enter a name for the new item and click OK.
The item will appear in the list on the left-hand side of the Calculations window.
A new variable added to the list at the left of the Calculations window, ready for its expression
If you want to delete an item, click on it in the list, then select Delete:
The Delete option on an item's own dropdown in the Calculations window
Variables
A Variable is an expression that is given a name to make it simple to refer to the expression in other parts of the Calculations window. Note that ‘variable’ is a homonym/homograph that in a different context has a different meaning; ‘variable’ is at times used to refer to a mineral such as gold or silver. In the context of calculations and filters, the meaning is aligned with the use of the word in mathematics and scripting languages.
Using a variable in calculations can make the calculations easier to read and understand. It also makes it simple to reuse an expression multiple times in different places. Any time you find the same expression appearing in different calculations, or in different parts of a calculation, split that expression out into a variable. You can even use a variable to represent a constant value, such as a particular density measure. You can use it to hold a value you want to change as you experiment. If the value is used in multiple places in other expressions and calculations, using a variable in those places means you only need to change the value in one place instead of many.
Numeric Calculations
A Numeric calculation is an expression that evaluates to a number, or a number for each point evaluation used as input. A numeric calculation can be viewed in the 3D scene as a points object.
Category Calculations
A Category calculation is an expression that evaluates to text, usually used to label a category or classification such as a lithology or grade description. If a points object is used as input, each point will be assigned a text label to categorise it according to the evaluation value. A category calculation can be viewed in the 3D scene as a points object.
RGB to Hex Colour
An RGB to Hex Colour is a special evaluation, in conjunction with the rgb_to_hex function, that combines separate columns of red, green and blue colour values into an RGB hex form that can be used within Leapfrog Works for colouring.
Not all tables support the RGB to Hex Colour calculations type.
Filters
A Filter is an expression that limits the data to specified constraints. When viewing a points object in the scene view, filters can be selected in the properties panel’s Query filter option to constrain which points are displayed.
Not all tables support filters as part of Calculations; the object may support Query Filters instead.
Understanding Errors Reported in the Errors Pane
Items in the Existing items list or in the Syntax and functions list can be selected and added to the Calculations pane. While a calculation or filter is incomplete, the Error pane will identify what is needed to make the calculation valid.
The errors pane will report when the syntax of an expression cannot be validly interpreted. It cannot report when the expression is not correctly structured to do what was intended.
While you are in the process of constructing an expression, errors will be reported when the incomplete expression cannot be validly interpreted:
A syntax error reported for a variable whose expression has been left blank
The messages provide the reason the expression is not valid or complete, but it cannot tell you how to complete or correct the equation.
A syntax error listing what the incomplete expression could be continued with
Other errors will be displayed when the type of result doesn't match the sort of calculation selected when it was created. A numeric calculation needs to produce numbers, a category calculation needs to produce text results, and filters need to produce true or false (boolean) results.
A type error, where a true or false expression has been given to a numeric calculation
Text needs to be identified by enclosing it with quotation marks, so it is not mistaken by the calculation engine as some sort of unspecified constant.
A reference error, where unquoted text has been read as the name of something that does not exist
A processing error indicates a problem executing part of the calculation for at least one of the points. The function may be syntactically correct, but the calculation cannot be performed for one or more points for some other reason. In the example below, number will not be able to be calculated if magnitude is ever below 3, as that will result in a divide by zero error. Because magnitude ranges from about 0.1 upwards, this does indeed cause a processing error. Not all processing errors will be divide by zero errors. The list of problems that will be reported as processing errors includes:
  • divide by zero
  • log of zero or a negative number
  • log base of 1
  • raising a negative number to a fractional power
  • sqrt of a negative number
  • numeric overflow, producing a number outside the range -1e308 to 1e308
  • a null value (blank, outside, without_value) in a set
  • multiple instances of the same value in a set
  • referencing a column that has been deleted
  • referencing a column that contains processing errors
Some processing errors will report that the problem is due to 'above errors', referring to errors higher in the errors list.
Processing errors will include a count of the number of affected blocks. Note that processing errors will only show up in the error list once processing has completed. You may need to unpause process execution and Run All processes.
A processing error reporting division by zero, with a count of how many rows it affects
You may have more than one error shown. As a rule of thumb, address the errors at the top first, as this corrective action may address the subsequent error.
Two errors on one calculation, the second explaining that the equation cannot run because of the first
Building Calculations and Filters
Items in the Existing items list or in the Syntax and functions list can be selected and added to the Calculations pane. Wherever a dotted box appears in the Calculations pane, you can add items and operators. Select an insertion point by clicking the dotted box where the item is required. You will see that the colour of the dotted box turns from black to orange to indicate that it is the currently selected entry box. Insert an item from one of the lists by clicking on it.
An empty if block in the editor, with an item about to be clicked in the reference list to fill the selected box
Select additional operators, constants, evaluations or other items as required, or type in values.
A variable holding a complete expression, so it can be referred to by name elsewhere
Some items you insert include placeholders that need to be replaced. For example, here, a value needs to be entered at the cursor position and the terms ‘lower’ and ‘upper’ need to be replaced with other items.
Clicking a Complex Comparisons entry inserts its template into the expression, with placeholders left to replace
The if (::) conditional statement can have additional rows added to it. Insert the cursor where you want to insert a row and then click the Add Row button () and a row will be added above the selected line.
The add-row button inserting a new, empty condition row into an if statement above the current row
You can hold the Shift key to add the row below the cursor. To delete the selected row, click the Delete Row button ().
A calculation or filter can be renamed after it has been created. Click on its name and select Rename from the menu that appears:
The Rename option on an item's dropdown in the Calculations window
Examples of Variables
Variables can produce numeric, boolean, or text results. You may create a variable because using a variable in other expressions can make them easier to read and understand, or it can let you change a value in just one place, even though it is used in many expressions.
Three variables: a numeric constant, a text constant, and an expression that refers to the first two by name
While producing results similar to numeric calculations, category calculations or filters, variables cannot be viewed on the block model in the 3D scene.
Example of a Numeric Calculation
Numeric calculations must produce numeric results, or an error will be reported.
A numeric calculation multiplying two columns together
The results of the numeric calculation for the points object can be viewed in the 3D scene by right-clicking on the numeric calculation entry in the project tree and selecting View Object.
A finished calculation appears under a CALCULATIONS divider in the project tree, where it can be displayed like any other column
Example of a Filter
In this example, one of the selectors from the Complex Comparisons options was chosen from the insert list. The value that will be tested is to be added at the insertion point between the comparators, and the placeholder words ‘lower’ and ‘upper’ need to be replaced with constants.
A filter holding the lower and upper comparison template, before the placeholders are replaced
Here the numeric column [time] has been specified as the value that will be tested, and lower and upper limits have been specified.
The finished filter, selecting rows whose time value falls between 25000 and 125000
When you select View Object for the filter in the project tree, the Query filter is set to the selected filter in the shape properties panel.
A filter defined in the Calculations window appears in the project tree and in the Query filter list for the object
Example of a Category Calculation
This example uses a category calculation to organise events into quarters for the year 2014 using the if(::) conditional statement.
The if(::) conditional statement contains two lines by default. Note the guiding cues within the dotted entry boxes. The first line describes the test to be performed that, if it evaluates as true, will produce a specified result. The ‘otherwise’ condition on the second line captures all the tested conditions that did not evaluate as true in the test on the first line, and these all produce an alternate result:
An empty if block added to a category calculation
In this case, all the values outside of the range of the filtering expression [Year] = 2014 are outside the period of interest. We add the expression as the ‘test’ condition, and specify the label "2014" as the first result, and use the label "Not Considered" in the bottom line for the ‘otherwise’ condition. So the labels are not mistaken by the calculation engine as some sort of unspecified constant, make sure labels are identified using quotation marks:
The if block filled in, returning one label for 2014 and another for every other year
We need to extend this trivial example for organise the period into quarters, and to do this we can nest if(::) conditional statements. Replace the "2014" label with a new if(::) item:
A second if block nested inside the result of the first condition
Now if values pass the filter in the first test, they then get to be sorted using the second if(::) block. This time we will test the month field and if it is less than or equal to 3 we will classify this as "Q1":
The first quarter added to the nested if block
Shift-click the Add Row button (), and a new conditional row is added below the current one, where we can specify that a Month value less than or equal to 6 will be classified as "Q2". Only values between 4 and 6 will be classified as "Q2" as the first line will have already classified all the values under 4 as "Q1".
Repeat to add another row specifying a Month value less than or equal to 9 to be classified as "Q3".
This leaves the ‘otherwise’ row in the nested if(::) block to catch values above 9 which are labelled "Q4":
The finished calculation, sorting 2014 into four quarters by month and labelling every other year Not Considered
The new 2014_quarter calculation we have constructed can be added to the scene view. Click the Edit Colours button in the shape list to select which categories are visible.
The category calculation used as a colouring, so each quarter's earthquakes take its own colour in the scene
Null Values
Leapfrog Works can differentiate between different types of invalid or null values, which are shown in the Calculations window:
The Invalid Values group in the reference list, holding blank, error and the tests is_normal and is_blank
If you are using the Contaminants extension adding block models, you will have additional invalid values:
The larger Invalid Values group available for block models, adding without_value and outside and their tests
You can see how many points or blocks of each normal or invalid status occur in an evaluation by right-clicking on the evaluation in the project tree and selecting Properties:
The status counts for an evaluation, giving how many values are normal, blank, without value, outside or in error
Invalid values can be displayed in the scene. When a block model is displayed in the scene, you can choose between displaying evaluation values or the Status. Highlighted below is a Kriging evaluation, shown displayed on the block model. Next to the Kriging evaluation in the dropdown list is a Status option:
The Status option beside each evaluation and calculation in the colouring list, which colours the model by value status instead of value
When the status option is selected, the model is displayed by block status. Click Edit Colours to change what status values are displayed.
The block model coloured by status, with the legend setting a colour and visibility for each status value
With block model statistics, you can view statistics for all evaluations and calculations made on a block mode. Statistics can be broken down into categories and organised by numeric evaluations and calculations. See Viewing Block Model Statistics in the Block Models topic for more information.
