Importing Data From Central
When you are working on a Central project, you can import some data types from other projects on the same server. In this way, you can easily share data between projects and, if the data object is out-of-date, you can reload it from Central.
When import from Central is supported, right-clicking on a folder or data object will show an additional import option.
Import Polyline from Central in the Polylines folder right-click menu
Geological models and refined geological models imported from Central are imported as static geological models. See Creating a Static Copy of a Geological Model for information on how to work with static geological models.
For most data types, you can import data from revisions of the Central project and from the project’s files. Drilling data and data in OMF files, however, can only be imported from a project’s files.
Although drilling data can be published to Central, that is for the purpose of visualising the data in the Central Portal. Published drilling data cannot be imported into other Leapfrog Works projects.
The rest of this topic describes how to import and reload data from Central. It is divided into:
Object Availability
With the exception of drilling data and OMF files, data objects that can be imported from Central are those that have been:
  • Published to Central as part of a revision via Leapfrog. These appear in the Import From Central window in the Project History tab.
  • Uploaded to the project’s files via the Central Portal. These appear in the Import From Central window in the Files tab.
The two sources for a Central import: the Project History tab for objects published with a revision, and the Files tab for files stored in the project's data room
For more information on publishing data to Central, see the Publishing to Central topic.
When you publish a project revision to Central from Leapfrog Works and wish to make a data object available for use in other projects, make sure you select that object from those in the project:
The objects ticked when the revision was published, which determines what can later be imported from it
For example, in the project above, the data objects that will be available for use in other projects on the same Central server are:
  • The Topography mesh
  • The surfaces in the Lithology geological model
  • The surfaces in the AG_gpt and AS_ppm numeric models
Unticked objects such as the Distance to collar mesh, the topography inside Distance to collar mesh, the Lithology on 9/10/2020 geological model and the AU_gpt numeric model will not be available.
The same published objects listed in the Central Portal project tree for that revision
Importing Central Data Objects
To import data objects from Central, first make sure you are already connected to Central. Then right-click on the folder for the data type you wish to import and select the Import From Central option. In the window that appears, select one of the projects in the repository.
In the next window, there are two options, the Project History tab and the Files list:
The Project History tab of the Central import window, listing the objects published with the selected revision
In the Project History tab, select a revision to view its published objects, then click on a model to load its list of objects. The list displayed will depend on the type of data object you are importing. Here, the surfaces in the project are displayed:
Expanding a published geological model in the import window to reach its boundary, surface and volume parts individually
The Files tab shows any files that have been uploaded to the Central project’s files:
The Files tab of the Central import window showing the same data room contents as the Files tab of the project in the Central Portal
Whether you wish to import data from a revision or from a Central project’s files, use the Shift and Ctrl keys to select as many objects as required. Click Import to import the objects, which will be saved into the project tree. Objects imported from Central are displayed using a different icon. For example, here the meshes in the Central meshes folder are marked with the Central logo (), whereas the meshes in the Imported from files folder are not ():
Objects imported from Central sorted into the Central meshes and Imported from files subfolders
Updating Out-of-Date Objects
When your project contains objects imported from Central, you can check whether or not updates to those objects are available. To do this, click the button at the top of the project tree and select Check For Updates:
Check For Updates in the menu beside the clock counter in the Project Tree header
Progress will displayed at the bottom of the project tree:
The progress strip at the bottom of the project tree while Leapfrog checks for out-of-date Central objects
Once the check is complete, the number of objects that updates are available for is indicated in the project tree title bar. Click on the button to highlight each of the out-of-date objects in the project tree:
Two Central meshes marked out of date with clock icons, matching the count in the Project Tree header
The options for reloading an out-of-date object depend on whether you imported the object from a project’s files or from a project’s history.
When you have imported an object from Central, you have two options for updating out-of-date objects:
  • Reload From Central > Reload Latest imports the newest version of the object available in the Central project the object was originally imported from.
  • Reload From Central > Reload From History displays the file’s history so you can choose which version you want to use.
Right-click on a data object and choose one of these options.
When you select Reload From History, the colouring of each entry in the project’s history indicates whether or not that object is available in a revision:
  • The revision highlighted in green is the one you currently have in your project.
  • Revisions in white are those that have a copy of the object you’re reloading.
  • Revisions in red do not have a copy of the object you’re reloading.
  • The revision highlighted in blue is the one you have currently selected, which will be reloaded if you click OK.
For example, here the revision currently in the project is the one published on the Geo 6.0 branch on 22/04/2021, highlighted in green:
Choosing which revision to reload a Central mesh from in the project history
The revision on branch 2021r1 dated 31/05/2021 does not have a copy of this mesh and so is highlighted in red. All revisions in white have a copy of this mesh, and clicking OK will load the copy of the mesh from the Geo 6.0 branch published on 31/05/2021, highlighted in blue.
Appending Rows and Adding Columns to Data Tables
Data tables imported from Central also have options for appending new data rows and adding data columns.
See the Updating Tables topic for a discussion of the differences between reloading data, appending data and adding new data columns.
When you want to append new rows to a table, right-click on the table and select the Append from Latest File Version option. You will be prompted to select the project and file. Once you have selected the data source, the process is the same as described in Adding New Rows to Existing Data Tables in the Updating Tables topic.
When you want to add new columns to a table, right-click on the table and select either Import Column from Latest File Version or Import Column from File History. The from Latest File Version option will display the file and you can select additional columns to import, whereas the from File History option lets you select from the file history. In each case, the file’s contents will be displayed and you can select additional columns to import, as described in Importing Additional Columns to a Data Table in the Updating Tables topic
