Numeric Composites
Compositing numeric data takes unevenly-spaced drilling data and turns it into regularly-spaced data, which is then interpolated. Compositing parameters can be applied to entire boreholes or only within a selected region of the borehole. For example, you may wish to composite Au values only within a specific lithology.
There are two approaches to compositing numeric data in Leapfrog Works:
  • Composite the drilling data directly. Compositing parameters can be applied to entire boreholes or only within a selected region of the borehole. This creates a new interval table that can be used to build models, and changes made to the table will be reflected in all models based on that table. This process is described below.
  • Composites the points used to create an interpolant. This is carried out by generating an interpolant and then setting compositing parameters for the interpolant’s values object. This isolates the effects of the compositing as the compositing settings are only applied to the interpolant.
Intervals that have no data can have a significant effect when compositing data as they are ignored by the compositing algorithm. The effect of these missing intervals can be managed using the Minimum coverage parameter, but it’s best to assign special values where intervals have no data. For example, intervals that are missing data can be assigned a value of 0 or that of the background mineralisation. See Handling Special Values for more information.
Creating a Numeric Composite
Creating a numeric composite involves the following steps:
  • Selecting the compositing region
  • Setting the composite length
  • Setting residual length handling
  • Setting coverage
  • Selecting an additional weighting column (optional)
  • Selecting the output columns
To start the process of creating a numeric composite, right-click on the Composites folder and select New Numeric Composite. You will be prompted to select the compositing region. There are three options:
  • Entire Borehole. The same compositing parameters are applied to all values down the length of boreholes, regardless of unit breaks. See Compositing in the Entire Borehole.
  • Subset of Codes. Different compositing parameters can be set for each code down the length of boreholes. See Compositing in a Subset of Codes.
  • Intervals from other Table. Interval lengths from another table are used to determine composite lengths. The value assigned to each interval is the length-weighted average value, and there are no further compositing parameters to set. See Using Intervals From Another Table.
Each option requires a different set of compositing parameters, which are described below.
Once you have set up the composite, click OK to create the table, which will be saved to the Composites folder. Double-clicking on the table displays the data in its columns. Edit the table by right-clicking on it and selecting Edit Composited Table. You can view statistics on the table or for each individual column in the table. See Viewing Numeric Composite Statistics.
When compositing is carried out using the Entire Borehole option, the boreholes are divided into intervals wherever numeric data occurs and the parameters set in the Compositing tab are applied to all values down the length of boreholes.
The Compositing tab for an entire borehole composite, with the compositing length, residual end length handling, minimum coverage and weighting column settings
The order of the operations in numeric compositing is as follows:
  1. A compositing length is selected. This may or may not end up being the exact length of composited intervals, which will depend on subsequent parameters and the actual data.
  2. Determine how to handle short sections at the end of boreholes that are shorter than the compositing length.
    • If Distribute equally throughout borehole is selected, all the composited intervals will be revised and not be exactly the compositing length.
    • If Add to previous interval is selected, the last interval will be longer than the compositing length.
  3. Compare the total length of data in each composited interval to the Minimum coverage parameter. If the available data does not meet the threshold for an interval, that interval will not get a composited value.
  4. Determine how to weight the input data, if required.
  5. Derive a value for each of the composited intervals that passes the minimum coverage test.
Compositing Length
The Compositing length you set will depend on factors including the deposit style, the sampling method and raw sample length. You can view statistics on the drilling data table to get an idea of the distribution of interval lengths. Right-click on the drilling data table and select Statistics. In the window that appears, select the Interval Length Statistics option:
The Choose Statistics Type window with Interval Length Statistics selected at the bottom of the list.
Another consideration in selecting the composite length is choosing a length that will not split units. For example, if most intervals are 2m long, choosing a length of 1m or 5m will split some intervals so that an interval with a single value will be represented more than once in the composite intervals. If intervals are mostly 2.5m long, then a composite length that is 2.5m or a multiple of 2.5m would ensure that units are not split.
Note that the actual length of intervals in the composited table may be longer than that set by the Compositing length. This arises from residual segments at the ends of boreholes and where there is data missing down a borehole; the length of these residual segments will, in certain conditions, be added to the composite intervals further up the borehole. See Residual End Length Handling below for more information.
The full length of each borehole will seldom divide up exactly into a whole number of intervals of the specified Compositing length. For this reason, “residual segments” will occur at the end of each borehole and where there is data missing down the length of the borehole. In the Compositing tab, you can set a residual end length value, which is the threshold at which all short residual segments will simply be treated as composited intervals. You can then specify how residual segments that are shorter than the residual end length are handled. Options are:
  • Discard. If the residual segment is shorter than the Residual end length for a composited interval, it is discarded.
  • Add to previous interval. If the residual segment is shorter than the Residual end length for a composited interval, it is added to the previous interval. Note that when this occurs, the actual length of that last composited interval will be longer than the Compositing length specified.
  • Distribute equally throughout borehole. If the residual segment is shorter than the Residual end length for a composited interval, instead of discarding or appending it, redistribute the total length into equal-sized intervals by adjusting the compositing length. Note that when this occurs, the actual length of each composited interval will be different than the Compositing length specified:
    • If the residual is less than 50% of the specified Compositing length, the same number of whole downhole intervals is used but each interval will be slightly longer.
    • If the residual is equal to or more than 50% of the specified Compositing length, one extra downhole interval is added, and each interval will be slightly shorter to compensate.
When the residual segment is longer than the residual end length but the length of provided data within the residual segment also meets or exceeds the Minimum coverage for a composited interval, the residual segment will simply be treated as a composited interval, although it is shorter than the typical intervals. When the Minimum coverage proportion is not achieved, the data is discarded. See Minimum Coverage below for more information on this setting.
In the illustration below, a series of adjacent boreholes have varying lengths of small data intervals that will not make up a full composited interval. The Residual end length is 4.5, the option to Distribute equally throughout borehole has been selected and the Minimum coverage is 32%. The borehole data is shown in the centre, with the composited data shown around the boreholes.
Eight drillholes with differing residual lengths at their ends, some having the extra length spread through the intervals and others keeping it as a short composite interval at the bottom.
The left four boreholes have extra residual segments of 2m, 4m, 6m and 8m. The two boreholes with short lengths less than 4.5m show the extra length has been distributed across the borehole intervals for compositing, as seen by the borehole interval transitions not lining up with the 10m depth markers. The boreholes with extra lengths of 6m and 8m have had the lengths added as short composite intervals, as they exceeded the residual end length.
The right four boreholes have missing data of varying lengths. Again, the two boreholes on the left have had the residual segment length distributed across the borehole intervals for compositing, as seen by the interval transitions not lining up with the 10m depth markers. Even though the 4m residual end segment has only 25% data coverage, the selected action is applied because the residual segment is shorter than the residual end length. The 6m residual end segment has 83% data coverage, so the additional segment is added as a short composited interval. The 8m residual end segment on the very right has only 25% data coverage, so the data is discarded.
There is one further possible result, which results in smaller composited intervals than the Compositing length: when the residual length exceeds half the compositing length and it is being distributed equally. Here, three boreholes from the previous example are reproduced using the same compositing rule: the Residual end length is 4.5, the option to Distribute equally throughout borehole has been selected and the Minimum coverage is 32%. A new hole, BH115, appears alongside with the same assay data as the adjacent BH103. It has a different compositing rule applied: the Residual end length is 7 instead of 4.5. Because the residual end length is greater than 5, half the specified compositing length of 10, an extra compositing interval is used when distributing the values over the length of the borehole. Thus each of the composited intervals for BH115 are slightly smaller than the specified composite length of 10:
Four drillholes with differing residual lengths at their ends, some having the extra length spread through the intervals. The two right-most drillholes are the same assay data with different compositing rules applied, and the very right-most hole has shorter composited intervals than the set composite length.
Also compare BH115 with BH102, which has distributed the residual end length across the existing intervals, resulting in longer than specified composited intervals.
Minimum Coverage
The Minimum coverage parameter determines whether or not a value will be calculated for a composite interval, based on the data available in the input data table. The Minimum coverage is a threshold the input intervals must meet in order for a composited value to be calculated. If, for example, the Minimum coverage is 50%, a value will be calculated for a composite interval only when there is data in at least 50% of the borehole that informs the composited interval.
  • Setting Minimum coverage to 100% will result in composite intervals being assigned values only when there is data for all borehole intervals that inform the composite interval.
  • Setting Minimum coverage to 0% will result in all composite intervals being assigned values, even where input intervals have no data.
In the image below, several adjacent boreholes have various sized gaps in the drilling data, shown using the inner solid line. The outer translucent line represents the composited intervals, and as the Minimum coverage value was set at 32%, only the largest data gap resulted in a missing composited interval.
Five drillholes with data gaps of increasing size, where the composite bridges every gap except the largest, which is left without a composited interval.
Composite values are calculated for each composite interval. This is simply the length-weighted average of all numeric drilling data that falls within the composite interval.
Composite points are generated at the centre of each composite interval from the composite values.
Additional Weighting Column
If you use an Additional weighting column, the column selected must contain valid (positive) values for all of the composite’s output intervals. If this is not the case, you will receive a message saying the table cannot be created. If the column selected as the weighting column is also in the list of output columns, that output column will be composited using length-weighted averaging only.
Output Columns
In the Output Columns tab, select the columns to be added to the numeric composite table. Move selected items from the Available columns list to the Selected columns list by clicking an item then clicking the button. You can select multiple items by holding down Ctrl while clicking.
The Output Columns tab, with two assay columns moved into the Selected columns list and a warning below about missing numeric data
When compositing is carried out using the Subset of Codes option, some codes can be excluded from the composited table or the raw data from the Base column can be used. When compositing is applied to a code, the same parameters apply as for the Entire Borehole option, but different codes can use different Compositing length and Minimum coverage parameters.
The Subset of Codes tab, where each lithology code carries its own action, compositing length, residual handling and minimum coverage
For the Action column, select from:
  • Composite. Numeric data that falls within the selected code will be composited according to the parameters set.
  • No compositing. Numeric data is not composited within the selected code. The raw data will be used in creating the new data table.
  • Filter out. Numeric data within the selected code will excluded from the new data table.
See Compositing in the Entire Borehole above for an explanation of the Length, Min. coverage, Res. length, Res. handling and Additional weighting column parameters.
Once you have set the compositing parameters, click on the Output Columns tab to select from the available columns of numeric data. See Output Columns above for more detail.
When compositing is carried out using the Intervals from other Table option, first select the Base table. This is the table that will that will be used to determine the interval lengths in the composited table.
The Intervals from Table window, with the lithology table chosen as the source of the intervals and two assay columns moved into the Selected columns list
The value assigned to each interval will be the length-weighted average value, and you can use an Additional weighting column. This column must contain valid (positive) values for all of the composite’s output intervals. If this is not the case, you will receive a message saying the table cannot be created. If the column selected as the weighting column is also in the list of output columns, that output column will be composited using length-weighted averaging only.
There are no further compositing parameters to set. Click OK to create the table.
Once you have created a composited table, you can view statistics on the table or for each individual column in the table.
To view statistics for the table, right-click on it and select Statistics.
The Choose Statistics Type window offering Table of Statistics, Scatter Plot, Q-Q Plot, Box Plot and Interval Length Statistics.
See the Saved Statistics topic for an introduction to statistics in Leapfrog Works.
The Interval Length Statistics graph is a univariate graph, so for more information on the options available, see the Univariate Graphs topic.
Right-click on the table columns and select Statistics to view information about the composited values.
Univariate Graphs displays statistics on the composited values. The other two compositing options display statistics comparing data before and after compositing.
The Choose Statistics Type window for a composited column, offering Univariate Graphs, Compositing Comparison and Compositing Interval Lengths.
The double histogram, one displaying the distribution of the raw data and one displaying the distribution of the composited data, enables comparison of the two distributions of the same element before and after the compositing transformation. Impacts on the symmetry of distributions will be evident.
A compositing comparison, with the composited distribution drawn above the axis and the uncomposited one mirrored below, and a table of both sets of statistics at the left.
In the Histogram settings, you can choose between Inverted graphs, as shown in the image above, or Side by side graphs where the data for each histogram bin is shown in the traditional histogram style. Bin width changes the size of the histogram bins used in the plot.Percentage is used to change the Y-axis scale from a length-weighted scale to a percentage scale.
Besides this statistical view comparing the composited data with the original data, there is a different Leapfrog Works feature called Composite Comparison. For more information on this feature, see Composite Comparison.
This graph shows a double histogram of distributions of the interval lengths before and after compositing.
A histogram of interval lengths before and after compositing, the composited lengths concentrated in one bar against the spread of the raw lengths mirrored below.
In the Histogram settings, Bin width changes the size of the histogram bins used in the plot.Percentage is used to change the Y-axis scale from a length-weighted scale to a percentage scale.
Enabling Display summary statistics on plot will replicate the summary statistics for the dataset as a legend on the plot.
If a more concise legend is preferred with only the key statistics, enable Simplify summary statistics:
Viewing Numeric Composite Status
The behaviour of the numeric compositing can be observed in the scene by adding the boreholes to the scene and selecting composite_status as the colouring in the shape list.
Drillholes coloured by composite_status, green for composite, yellow for merged composite and red for residual, with the colouring dropdown outlined in the shape list.
There are four possible values for the composite status:
  • Composite. The interval, of the specified Compositing length, has been composited.
  • Merged Composite. The interval, which is longer than the specified Compositing length, has been composited with the additional length coming from distributed residual length.
  • Residual. The interval, which is shorter than the specified Compositing length, is either:
    • The short interval at the end of a borehole that is longer than the residual end length threshold, so is treated as a short composited residual end length (see BH103 and BH104 below).
    • All the short intervals in a borehole that have been composited and the residual end length has been distributed to all the intervals, but as the residual end length was greater than half the composite length, an additional interval was added, resulting in all the intervals being shorter than the composite length (see BH115 below).
  • Uncomposited. The interval has not been composited.
Drillholes coloured by composite_status, green for composite, yellow for merged composite and red for residual, with the legend displaying the colour key.
