Leapfrog Works/Seequent Evo Data Flow
In Seequent Evo, data is organised into workspaces where access is controlled by assigning users and granting them different permission levels. In a Leapfrog Works project, you can import data from the Evo workspaces you have access to. You can also publish data in the project to Evo workspaces you have Owner and Editor access to.
- Data imported from Seequent Evo is linked to the Evo workspace. You can import data into a Leapfrog Works project that belongs to different Evo workspaces, and you can publish objects in a project to multiple workspaces.
- When members of your team publish changes to Evo objects that are in your Leapfrog Works project, those objects will be marked as out-of-date in Leapfrog Works. The reloading of data from Seequent Evo does not happen automatically; you can choose when to reload an object and work with the updated object instead.
- Once you have modified an object in Leapfrog Works and you are satisfied with the changes you have made, you can publish the updated object back to Seequent Evo so that it can be accessed by other members of your team.
Separate topics describe how to import, publish and reload data:
