Enabling and Editing Vein Pinch Outs
When veins are created from drilling data, vein walls can be set to pinch out where drilling data does not include the designated vein lithology. Pinch outs are achieved by creating ‘outside’ intervals on boreholes that do not have an interior vein segment. These intervals are then flipped with respect to interior vein intervals, which, in effect means the footwall and hangingwall orientation has the opposite sense to the nearest interior intervals. This forces the hangingwall and footwall surfaces to cross, thereby pinching out.
The Pinch out option is disabled when a vein is first created. To enable it, double-click on the vein in the project tree and click on the Surfacing tab. Tick the box for Pinch out:
The pinch out settings on a vein's Surfacing tab, with the main Pinch out checkbox clear so the three options beneath it are greyed out.
For this vein, the green cylinders indicate vein lithology intervals. The surface continues to the boundary even where there are no boreholes that have vein lithology intervals:
A vein with pinch out disabled, its surface continuing out to the boundary as a broad sheet even where no drillholes intersect it.
When the vein is set to pinch out, it tapers out where there is no vein lithology data:
The same vein with pinch out enabled, its surface tapering away and opening into gaps wherever the drillholes carry no vein lithology.
There are two further settings that relate to whether or not a borehole trace has data logged:
  • The Pinch out on completely empty traces setting relates to whether or not pinch outs are created for boreholes where no lithology data has been logged, neither vein nor background lithology.
  • The Don’t pinch out on empty intersections in logged holes setting relates to whether or not pinch outs are created for boreholes that have data logged that intersects the vein’s hangingwall and/or footwall surfaces.
There is also the option to manually exclude some pinch out segments. Each of these is discussed in detail below:
Pinch Out on Completely Empty Traces
The Pinch out on completely empty traces setting relates to whether or not pinch outs are created for boreholes where no lithology data has been logged, neither vein nor background lithology. Enabling the setting results in pinch outs being created where such traces intersect the vein footwall and/or hangingwall surfaces, resulting in a final vein that is empty around those pinch outs.
To illustrate the effect of this setting, we have an artificial dataset that has four traces with no logged data. When Pinch out on completely empty traces is disabled, the vein does not pinch out where it there are no actual vein segments:
A vein with Pinch out on completely empty traces disabled, its surface continuing unbroken through the drillholes that carry no logged data.
When the option is enabled, however, pinch outs (pink) are created around the empty traces and the vein pinches out around them:
The same vein with Pinch out on completely empty traces enabled, the surface now pinched away around the unlogged drillholes and leaving a hole through the middle.
Don’t Pinch Out on Empty Intersections in Logged Holes
The Don’t pinch out on empty intersections in logged holes setting relates to whether or not pinch outs are created for boreholes that have data logged that intersects the vein’s hangingwall and/or footwall surfaces. Whether or not the logged lithology ‘intersects’ the hangingwall and/or footwall surfaces is determined by a distance parameter; if there is logged data but it fall outside the distance specified, the intersection is regarded as ‘empty’ and no pinch out will be created.
Again, we have an artificial dataset to illustrate the effect of this setting. Here there are two boreholes (A and B) that do not contain the vein lithology; they do, however, contain other lithologies and so are regarded as logged. The scene is sliced and so the lines (C) show where the vein’s hangingwall and footwall surfaces intersect each borehole. We can see that A has a logged interval that directly contacts the hangingwall surface, whereas the logged interval (D) in borehole B is quite distant from the footwall surface:
A worked example showing two drillholes either side of a vein, one whose logged interval meets the vein surface and one at B whose logged interval at D sits some distance away from it.
Enabling only the Pinch out setting creates pinch outs where both boreholes intersect the vein, which is as expected:
With only Pinch out enabled, pinch outs are created at both drillhole intersections, marked in magenta at A and B.
Enabling Don’t pinch out on empty intersections in logged holes results in the vein pinching out where it intersects borehole A, but it does not pinch out for borehole B:
With Don't pinch out on empty intersections in logged holes enabled at a distance of zero, the vein still pinches out at A but no longer pinches out at B.
This is because the interval in borehole B is outside the distance specified and so the intersection between the vein and borehole B is regarded as empty.
Increasing the distance value results in the vein also pinching out where it intersects borehole B:
Raising the distance value to ten brings the far drillhole back within range, so the vein pinches out at B as well as at A.
The distance value can be used to indicate how far away logged data can be while still informing the vein surface. If, however, it does not seem geologically reasonable to adjust vein pinch out behaviour in this way, an alternative is to manually exclude some pinch out segments.
Manually Excluding Pinch Out Segments
You can change how much a vein pinches out by manually excluding some pinch out segments. To do this, right-click on the pinch out segments () in the project tree and select Edit in Scene:
The Edit In Scene command on a vein's pinch out segments in the project tree.
If you manually edit pinch outs, you can export the edits for use in other veins and models in the current project or in other projects. The edits are exported in a text file. See the Exporting and Importing Vein Edits topic for more information.
You can also add the pinch out segments to the scene and click the Edit button () in the shape list:
The edit button on the pinch out segments row in the shape list, with a tooltip reading Edit vein.
The Vein Pinchout Segments will appear, along with a set of tools for selecting segments in the scene:
Pinch out segments open for editing in the scene, with the segment selection tools in the toolbar and a panel for assigning segments to either Pinch Out or Excluded.
To select segments, click on the Select segments button () and click the Add segments button (). In the scene, draw a line across each segment you wish to select:
A line drawn across a pinch out segment in the scene, with the segment highlighted and the select and add segment tools active in the toolbar.
Note that the segments displayed in the scene below are the pinch out segments rather than the borehole segments shown in earlier scenes. The grey segments are excluded and the currently selected segment is highlighted in the scene.
Selected segments are highlighted in the scene. If you accidentally select the wrong segment, either:
  • Click the Remove segments tool () and draw across the point once again.
  • Hold the Ctrl key while drawing across the point.
You can also:
  • Select all visible segments by clicking on the Select all tool () or by pressing Ctrl+A.
  • Clear all selected segments by clicking on the Clear selection tool () or by pressing Ctrl+Shift+A.
  • Swap the selected segments for the unselected segments by clicking on the Invert selection tool () or by pressing Ctrl+I.
To change the width of the line used to select segments, click on the Change line width button () and enter a new value. You can keep the Set Line Width window open while you select intervals so you can change the line width as required:
The Set Line Width window, with the selection line width set to 10 and an arrow pointing to the change line width button in the toolbar.
When you have selected at least one segment, click on the Assign to button, then select the category you want to assign the selected segments to:
The Assign to menu open on the Excluded category, with arrows running from the two selected segments in the scene to that menu entry.
The selected segments will be updated to reflect the change:
The two reassigned segments now drawn in grey rather than magenta, showing that they have been excluded.
Click the Save button () to view the effect of the excluded pinch out segments on the vein. In this example, excluding the two segments results in the vein terminating at the boundary of the geological model:
The rebuilt vein, which now continues as a broad sheet out to the boundary of the geological model instead of pinching out at the two excluded segments.
