Importing and Reloading Points Data
Leapfrog Works imports the following file types for points data:
  • CSV Text Files (*.csv)
  • ASCII Text Files (*.asc)
  • DXF Files (11/12 [AC1009]) (*.dxf)
  • Data Files (*.dat)
  • Leapfrog Works 3D Point Data files (*.pl3, *.ara)
  • XYZ Files (*.xyz)
Points data can be imported from:
  • Files stored on your computer or a network location. Right-click on the Points folder and select Import Points > Local. You will be prompted to select a file.
  • Data stored in Central. Right-click on the Points folder and select Import Points > Central.
  • Data stored in Seequent Evo. Right-click on the Points folder and select Import Points > Seequent Evo.
  • From any database that runs an ODBC interface. Right-click on the Points folder and select Import Points > ODBC. See Selecting the ODBC Data Source below.
For each of these options, once the data source is selected, the process of importing the data is the same.
Leapfrog Works expects East (X), North (Y) and Elev (Z) columns.
You can also import a holeID column, although this is optional.
When importing a file that has multiple features, you will be prompted to select which ones to import. You can also choose to:
  • Import the features as separate objects. Each feature will appear in the project tree as a separate object.
  • Flatten all features into one object. Leapfrog Works will treat all features as a single object.
Once imported, the file will be added to the Points folder. If there are errors in the data, the errors can be corrected as described in Identifying and Correcting Data Errors in Leapfrog Works.
To view the imported data, double-click on the object that has been added to the Points folder.
Once points data has been imported to the project, it can be modified and evaluated against geological and numeric models, as described in Evaluating Points Data.
When importing points data from an ODBC database, you will need to specify the ODBC data source. Enter the information supplied by your database administrator and click OK.
Importing Time Dependent Points
Importing time-dependent points requires the Contaminants extension.
Leapfrog Works imports time-dependent points in CSV format. To do this, right-click on the Points folder and select Import Time Dependent Points. Leapfrog Works will ask you to specify the file location. Click Open to import the file. Leapfrog Works will display the data and you can select which columns to import.
Click Finish to import the file, which will appear in the Points folder.
Time-dependent points can be filtered in the scene by another numeric column, e.g. a time or date column. This enables, for example, micro-seismic data to be visualised over time using a range slider. To view data in this way, click on the points table in the shape list, then select a time or date column as the Display filter in the properties panel:
The properties panel for a points table with the Display filter set to a time column, and the Enable filter box, date buttons and range slider that restrict which points are shown
Next tick Enable filter and either click the date buttons to set the upper and lower limits or use buttons on either end of the slider.
A range slider in coarse control mode, shown dark blue with its handles at each end covering the full range of 1 to 160
The same range slider with its handles dragged in to restrict the range to 1 to 50
Dragging the selected section of a range slider to move the displayed range along, here to 52 to 101
Double-clicking a range slider switches to fine control, expanding the selected range of 52 to 101 across the whole slider
In fine control mode, moving the handles inwards further restricts the range from 52 to 101 down to 60 to 80
Right-clicking a range slider returns it to coarse control, restoring the earlier range of 52 to 101
Reloading data is necessary when the imported data is modified externally. Points data can be reloaded by right-clicking on the table and selecting Reload Data.
Reloading points data overwrites all data in the existing table. If you have data you wish to add to the project without overwriting existing data, use the Append Data option.
The process is similar to that for importing the original table.
Appending Points Data
If points data is stored in multiple files, you can import these files into the project and add them to existing points data. To do this, right-click on the object you wish to append and select Append Data. You will be prompted to select a file.
Next, the Import Tables For Appending window will be displayed.
Check the data to ensure that the correct information will be imported, then click Finish to add the new file.
See Adding New Rows to Existing Data Tables in the Updating Tables Topic for more information.
Importing a Column
Columns of points data that were not imported when the original data was imported or that are stored in a separate file can be added to the table at any time. To do this, right-click on the points table in the project tree and select Import Column.
The process is similar to importing the original table; select the file and map the columns you wish to import.
