Interval Selection
When you wish to select a small portion of intervals or you don’t have suitable parameters to use a query filter, you can select intervals from boreholes displayed in the scene to create a new lithology column. The original lithology column is preserved and a new lithology column is added to the interval table. You can then select the original lithology column or the new one when displaying data and creating models.
To start selecting intervals, first add the borehole data to the scene. Then right-click on the interval table in the project tree and select New Column > Interval Selection. For a merged table, right-click on it and select Interval Selection.
The New Lithology Column window will appear:
The Interval Selection window will appear, together with a set of tools that will help you to select intervals in the scene. To select intervals, click on the Select Intervals button (
- Click the Remove Intervals button (
You can also:
- Select all visible intervals by clicking on the Select All button (
) or by pressing Ctrl+A. - Clear all selected intervals by clicking on the Clear Selection button (
) or by pressing Ctrl+Shift+A. - Swap the selected intervals for the unselected intervals by clicking on the Invert Selection button (
) or by pressing Ctrl+I.
To change the width of the line used to select intervals, click on the Change Line Width button (
) and enter a new value. You can keep the Set Line Width window open while you select intervals so you can change the line width as required.
) and close the Interval Selection window. The new lithology column will appear in the project tree as an additional lithology column in the interval table. Select the new column from the shape list to display it:
