Category Composites
In Leapfrog Works, you can composite category data in two ways:
  • Composite the borehole data directly. This creates a new interval table that can be used to build models, and changes made to the table will be reflected in all models based on that table. This process is described below.
  • Composite the points used to create an object.
The rest of this topic describes compositing borehole data directly.
Right-click on the Composites folder, which is in the project tree as part of the Boreholes object, and select New Category Composite. You will be prompted to select from the category columns available in the borehole data. Next, the New Composited Table window will appear, showing the options for sorting intervals in the selected column:
  • Primary. This is the unit of interest. In the case of compositing on intrusion contact surfaces, this will be the interior/intrusive lithology.
  • Ignored. These are units that are, generally, younger than the unit of interest and should, therefore, be ignored in generating contact surfaces.
  • Exterior. These are units that occur outside of the unit of interest. For an intrusive lithology, other lithologies the intrusion contacts should be classified as Exterior.
Converting Ignored Segments
The Convert enclosed ignored segments setting determines how ignored segments are handled when they are flanked by either two interior segments or two exterior segments. If Convert enclosed ignored segments is enabled, Leapfrog Works will convert enclosed ignored segments to match the surrounding segments. In cases where an ignored segment does not lie between two interior or exterior segments, it will remain ignored.
For example, this scene shows two ignored segments that are flanked by the unit of interest. Because Convert enclosed ignored segments is disabled, the segments remain ignored:
Enabling Shorter than and setting it to 4 results in the shorter segment being converted to the Primary unit and the longer segment remaining Ignored:
Zooming out, we can see that the ignored segments at the top of the boreholes have not been converted:
Filtering Short Segments
The Filter primary segments and Filter exterior segments parameters determine how short a segment must be before it is composited:
  • Short Exterior segments flanked by Primary segments will be converted to Primary segments.
  • Short Primary segments flanked by Exterior segments will be converted to Exterior segments.
When the value is set the zero, no segments will be converted.
To see how these parameters can smooth the shape of a unit of interest, let’s look at a series of boreholes where we wish to create an intrusion boundary based on the red segments. Short segments are highlighted in the intervals that have not been composited:
The Interval Length Statistics graph is a univariate graph, so for more information on the options available, see Univariate Graphs in the Analysing Data topic.
