Structural Data
In Leapfrog Energy, you can create and edit planar structural data tables directly or from other objects in the project. Structural data can also be used to create and edit many surfaces. Downhole planar structural data and lineations can also be imported, although structural data imported in this way cannot be edited.
This topic describes how to work with structural data in Leapfrog Energy. It covers:
- Importing Lineations
- Extracting Structural Data From Meshes
- Displaying Structural Data
Leapfrog Energy calculates strike using the American right-hand rule; when looking in the strike direction, the plane should dip to the right.
There are two ways to create a new planar structural data table in Leapfrog Energy:
- Create a new table as part of creating or editing another object. See Editing Surfaces With Structural Data.
Leapfrog Energy supports planar structural measurements in the following formats:
- ASCII Text Files (*.asc)
- CSV Text Files (*.csv)
- Data Files (*.dat)
- Plain Text Files (*.txt)
- TSV Text Files (*.tsv)
This topic describes importing structural data tables that include location information. Downhole structural data can also be imported, as described in Importing Downhole Planar Structural Data in the Importing Additional Tables topic.
- Files stored on your computer or a network location. Right-click on the Structural Modelling folder and select Import Planar Structural Data > Local. You will be prompted to select a file.
- From any database that runs an ODBC interface. Right-click on the Structural Modelling folder and select Import Planar Structural Data > ODBC. See Selecting the ODBC Data Source below.
For each of these options, once the data source is selected, the process of importing the data is the same. Leapfrog Energy will display the data and you can select which columns to import:
Leapfrog Energy expects East (X), North (Y), Elev (Z), Dip and Dip Azimuth columns. The Polarity column is optional. The Base Category column can be used for filtering data once it has been imported.
Once the data has been imported, you can add new columns and rows and reload the data, which is described in the Working With Data Tables topic.
Lineations containing location information can be imported from files stored on your computer or a network location in the following formats:
This topic describes importing lineation files that include location information. Downhole lineations can also be imported, as described in Importing Downhole Lineations in the Importing Additional Tables topic.
To import a lineations file containing location information, right-click on the Structural Modelling folder and select Import Lineations. You will be prompted to select a file.
Leapfrog Energy expects East (X), North (Y), Elev (Z), Trend and Plunge columns. The Polarity column is optional. The Category column can be used for filtering data once it has been imported.
Once the data has been imported, you can add new columns and rows and reload the data, which is described in Adding and Updating Data for Existing Tables in the Working With Data Tables topic.
Meshes can be converted into structural data, with each triangle face being interpreted as a structural data disk. Right-click on a mesh object in the project tree and select Extract Structural Data. You will be prompted to provide a name, and there are a couple of additional options for open meshes. The Use clipped mesh option is only available on open meshes with a clipped mesh; the Ignore edge triangles option is only available on open meshes. When you click OK, a corresponding structural data object will be added to the Structural Modelling folder in the project tree.
The categories displayed can also be filtered by other columns in the data table, as described in Using the Display Filter.
Bingham Analysis
Fisher Statistics
There are two ways to initiate structural data selection: from the data object in the project tree/shape list and from a stereonet. The advantage of initiating structural data selection from a stereonet is that the data will be displayed both on the stereonet and in the scene window. This provides the most flexibility for analysing what data belongs to what category. See Selecting Data in the Stereonet and Using the Scene Window With the Stereonet for more information.
- Edit the data in the table directly by double-clicking on the structural data table in the project tree. See Working With Data Tables.
You can find more information on the results of the declustering by right-clicking on the declustered set in the project tree and selecting Properties:
Unprojected points are data points that do not vertically intersect the selected surface. There are three options:
