Working With Data Tables
Leapfrog Energy has tools for importing, creating and working with many different types of data, which are described in the Data Types topic.
An important part of working with data in Leapfrog Energy is working with data tables. This topic provides an overview of how to work with data tables and is divided into:
Subsequent topics describe further aspects of working with data tables such as:
Data Tables in the Project Tree
For most tables in a Leapfrog Energy, you can view what columns it contains by expanding the table in the project tree. Here a points table contains three numeric data columns () and two category data columns ():
A points table in the project tree with its numeric and category data columns listed beneath it
Some table columns are not shown in the project tree, such as text or URL columns that cannot be visualised in the scene.
For mesh and polyline attribute tables, the data columns are not shown in the project tree. To view the attribute columns, right-click on the table in the project tree and select Attribute Table.
Viewing Table Data
To view the contents of most data tables, double-click on them in the project tree. A window will appear showing all data in the table. To view the contents of attribute tables for objects such as GIS objects, meshes and polylines, right-click on the object and select Attribute Table.
Tools for working with tables include:
  • Fixing errors (A) that have been detected in the table. See the Identifying and Correcting Data Errors in Leapfrog Energy topic.
  • Building or applying a query filter (B). See the Filtering Data topic for more information on how to build and use queries.
  • Selecting rows and setting them to be ignored (C). If the Ignored column is ticked, then Leapfrog Energy completely ignores that row, as though it has been deleted. This is useful for suppressing erroneous data from being processed.
An opened table showing the Fix Errors button (A), the query builder (B) and the Ignored column (C) that excludes a row from processing
If a row in a collar table is ignored, then all other data associated with that hole (e.g. surveys and interval measurements in other tables) are also ignored.
Collar tables have a trench column that indicates whether or not the well is from a trench. When the trench column is ticked for a well, the trench will be desurveyed in a different manner from other wells. See The Raw Tangent Algorithm for more information.
Cells in a table are editable, apart from the id column, which Leapfrog Energy uses as unique identifier. Double-click in a cell to edit it. If the cell you wish to edit is already selected, press the space bar to start editing.
When you edit a cell, the change will be indicated in bold text:
An edited cell in an opened table, shown in bold until the table is saved
When you save the table, the edited text will no longer be displayed in bold.
Deleting Columns
For column types that are displayed in the project tree, you can delete them by right-clicking on them in the project tree and selecting Delete. You will be asked to confirm your choice, as any objects in that project that have been created from that data column will also be deleted.
Right-clicking a column in the project tree and choosing Delete, which asks for confirmation and lists what else will be deleted
Some table columns are not shown in the project tree, such as text or URL columns that cannot be visualised in the scene. To delete one of these ‘hidden’ columns, right-click on the table and select Delete Column. All columns in the table will be listed, including hidden columns such as the Cores column here, which is a column of URLs:
The Delete Column submenu, which lists hidden columns such as Cores alongside the ones shown in the project tree
For mesh and volume attribute tables where the data columns are not shown in the project tree, you can delete or rename columns by first opening the table. You can then delete or rename a column by clicking on its header:
Clicking a column header in an opened attribute table, which offers Delete and Rename
Renaming Columns
For most tables, you can rename columns by right-clicking on them in the project tree and selecting Rename. If you later export the table and wish to use your new column name in the exported table, make sure you untick the Use original column names option:
The Use original column names option in the export window, which must be unticked for renamed columns to keep their new names
For attribute tables, open the table, click on the column you wish to rename, then select Rename.
Evaluating Models
You can evaluate models onto data tables, as described in Evaluations. Evaluated models will appear under the table as a separate set of objects:
Models evaluated onto a table appear beneath an EVALUATIONS divider in the project tree
Copying a Table Schema (Mesh Attributes)
For some meshes, you can share the attribute table schema. This is useful when you have defined a set of attributes for a mesh and want to use those same attributes for other meshes in the project.
Only the table schema is shared, not the table data itself. Copying a table schema to another table does not link the two tables; changes made to the schema for one table will not affect the other.
In the project tree, right-click on the attributes table you wish to share and select Copy Table Schema to.
Right-clicking a mesh's attribute table and choosing Copy Table Schema to
In the window that appears, meshes the table schema can be shared with are listed. Select those you wish to share your table schema to and move them into the Selected meshes list:
The Select Meshes window, with two meshes picked and about to be moved into the Selected meshes list
Click OK. The table schemas will be updated.
