Merging Drilling Data Tables
When you have more than one interval table in drilling dataset, you can create a new table using selected columns from existing interval tables. You can include columns created by, for example, grouping or splitting lithologies or compositing.
You cannot create a merged table from interval tables in different drilling datasets.
To create a merged table, right-click on a drilling dataset in the project tree and select New Merged Table. The New Merged Table window will appear showing all interval columns available in the drilling dataset:
The New Merged Table window, listing all the interval columns available in the drilling dataset for moving into the selected columns list.
You can change the columns included once you have created the table.
Select the columns you wish to include in the new table and click OK. The new table will appear in the project tree as part of the drilling dataset:
The New Merged Table window, where the columns to include are moved into the Selected columns list and the new table is named.
You can create query filters for a merged data table, as described in the Filtering Data topic. You can also select intervals (see Selecting Intervals) and create an overlaid lithology column (see Overlaid Lithology Column). You cannot, however, use the group lithologies and split lithology tools on a merged table.
To edit the table, right-click on it and select Edit Merged Table.
