Displaying Drilling Data
Viewing drilling data in the scene is an important part of refining drilling data and building a geological model. Therefore, Leapfrog Energy has a number of different tools for displaying drilling data that can help in making drilling data processing and modelling decisions.
Display drilling data in the scene by dragging a drilling dataset into the scene. You can also drag individual tables into the scene.
To display the data associated with each interval, click on the Show text button () in the shape list. Here, data display is enabled for two interval tables:
Two drillholes in the scene with interval values and lithology names displayed, and arrows linking the displayed text to the Show text buttons enabled for two interval tables in the shape list.
The Show trace lines button () in the shape list displays all trace lines, even if there is no data defined for some intervals. The Filter trace lines option in the shape properties panel displays only trace lines for wells selected by a query filter. See Using a Filter in Displaying Data in the Filtering Data topic for more information.
The rest of this topic describes the different ways of displaying drilling data. It is divided into:
Displaying Wells as Lines or Cylinders
You can display wells as lines or cylinders. You can also display the data associated with each segment. Here, the wells are displayed as flat lines:
Six drillholes displayed as flat coloured lines in the scene, with the Line width property in the shape properties panel setting how wide the lines are drawn.
The width of the lines is set in the shape properties panel.
When the Make lines solid button () is enabled, the wells are displayed as cylinders and the property that can be controlled is the Line radius:
The same drillholes displayed as solid cylinders after enabling Make lines solid, with the Line radius property controlling their thickness.
When numeric data is displayed, there is an additional option, to use a data column in the table for the cylinder radius:
A drillhole cylinder whose radius varies with its values, produced by choosing a data column in the Radius values field of the shape properties panel.
When the log button () is enabled, the log of values is used for the radius.
Enhancing High Values
When viewing drilling data as lines with Make lines solid disabled, each data point is rendered in the scene as a square. When the scene is zoomed out to view the wider context, low value sample points can conceal high value sample points. This is because the sample points overlap when rendered in the scene, and when the square representing a low value is rendered, any high value point behind that low value point will be partly or completely hidden.
A dense set of drillholes viewed at a distance with Enhance high values off, where low value sample points conceal much of the high value data.
Enabling the Enhance high values option reveals those previously concealed points. Instead of the lower-value point concealing the higher-value point, the higher value point will be rendered on top in the scene.
The same drillholes with Enhance high values enabled, so that the higher value points are drawn on top and the high grade cluster becomes visible.
This reveals the high value region of interest. A drawback of viewing with Enhance high values enabled is that individual wells may appear to weave oddly due to the way the points are rendered. However, visually following specific wells is usually not important at these view scales. When zooming in to see the detail of well paths, the reduction or lack of overlapping sample points will result in Enhance high values having little visual effect.
Enhance high values can be used to find trends of higher-grade material in a densely drilled region. It is best used while rotating the scene to visualise the location of the high values:
Animation showing the scene being rotated with Enhance high values enabled, so the concentration of high grade samples stays visible from every viewing angle.
Enabling Enhance high values will disable Make lines solid as these are incompatible viewing options.
Hiding Lithologies
When lithology tables are displayed, you can hide some of the lithologies to help make better sense of the information in the scene. Click on the Edit Colours button in the shape list. In the window that appears, use the Show/Hide buttons () to determine what segments are displayed:
The Legend for Lithology window opened from Edit Colours, where the Show/Hide button beside each lithology determines whether its segments appear in the scene.
To select multiple lithologies, use the Shift or Ctrl keys while clicking. You can then change the visibility of all selected lithologies by clicking one of the visibility () buttons.
Hiding lithologies in this way only changes how the data is displayed in the scene. Another way of limiting the data displayed is to use a query filter (see Using a Filter in Displaying Data in the Filtering Data topic), which can later be used in selecting a subset of data for further processing.
Displaying a Legend
To display a legend in the scene, click the Show legend button () for the table:
A lithology legend displayed in the scene, produced by the Show legend button in the shape list, with the arrows in the Legend window used to reorder the entries.
The legend in the scene will be updated to reflect lithologies that are hidden in the scene when you click Edit Colours and hide some lithologies.
Changing Colourmaps
To change the colours used to display lithologies, click on the Edit Colours button in the shape list. In the window that appears, click on the colour chip for each lithology and change it as described in Single Colour Display Options.
Use the Shift or Ctrl keys to select multiple codes. This is useful for moving multiple codes up and down in the list.
You can also import a colourmap, which is described in the Category Colourmaps topic.
Viewing Multiple Interval Tables
When viewing multiple interval tables, use the line and point size controls and the transparency settings to see all the data at once. For example, here, the geology table has been made transparent to show the contaminant intervals inside:
Two interval tables shown together, with the geology cylinders made transparent so the contaminant intervals inside them remain visible.
Selecting From Multiple Columns
When an interval table has more than one column of data, select the column to view from the view list:
The view list on an interval table opened to show the columns available, with Simple_RockType selected.
Some columns are editable, in which case you can click on the Edit button () to start editing the table:
The Edit button that appears on the shape list row when the displayed column is editable.
Displaying Interval Data in the Scene
Wells can be displayed with the data associated with each segment. For example, in the scene below, contaminant values are displayed along the well:
Drillholes in the scene labelled with the contaminant value of each interval alongside the trace.
To view data in this way, select the table in the shape list, then click on the Format Display Text button. In the Text Format window, click Insert Column to choose from the columns available:
The Text Format window opened from Format Display Text, with the Insert Column dropdown listing the columns that can be added to the displayed text.
You can display multiple columns and add text:
The Text Format window with two column tokens and typed labels combined, so each interval is annotated with both values.
Click OK to update the formatting in the scene. You can conceal the formatting in the scene by clicking on the Show text button () in the shape list:
The Show text button in the shape list, which shows or conceals the interval text displayed alongside the drillholes in the scene.
Clear text formatting by clicking on the Format Display Text button, then on the Delete button ().
Displaying a Survey Table
When you add the survey object () to the scene, each of the survey point measurements is shown using a tangent cone pointing in the surveyed point's downhole direction. The Show text button () will show or hide the associated value alongside the tangent cone. The cone can be assigned a colour using the view list.
When the survey object is selected in the shape list, the properties panel will show options to adjust:
  • Cone length. The size of the tangent cone.
  • Scale values options. These modify the size of the tangent cone using a selected factor or keeping the Fixed Length specified in Cone length. There is also the option to click the Use log of value for length button () for value ranges that will benefit from the log scaling.
  • Decimal places. This specifies the precision of the label shown in the scene.
Survey points displayed as tangent cones coloured and labelled by dogleg severity, with the cone length, scaling and decimal places set in the shape properties panel.
Displaying Hole ID Labels
The hole ID label can be positioned either at the start or the end of the well to suit what is most legible. For instance, when holes are drilled in a fan shape, the labels can overlap making them hard to read.
Hole ID label position can be found in the shape properties panel when a well trace object or planned wells object is selected in the shape list. Select either Start or End as preferred.
A fan of drillholes with their hole ID labels placed at the end of each hole, set by the Hole ID label position option in the shape properties panel.
Displaying Well Traces
Adding the traces object () to the scene can be useful in visualising the extent of drilling. You can change the colour used to display the traces, and they can be displayed as lines or cylinders. You can also display depth markers in the scene. To do so, click on the traces in the shape list and enable the Show depth marks option:
Drillhole traces with depth marks displayed, and the Show depth marks options in the shape properties panel controlling tick spacing, size, labelling and side.
Depth markers can be displayed with or without text. Enable the Show text option (()) to display the depth values. This option also displays the hole ID, which can be displayed at the start or the end of the well.
Planned wells can also have depth marks applied to the planned well trace.
Displaying Well Graphs
Downhole numeric data can be displayed in the scene as a bar graph and downhole points data can be displayed as a line graph. To display downhole data in this way, add the graphs object () to the scene. The Well Graph Style Manager will be displayed, showing the data columns available:
The Well Graph Style Manager, listing the columns available to plot and the options for the graph's position, scale, colouring and display range, with bar graphs drawn beside the traces in the scene
Data can be displayed to the right or the left of the well trace. Use the sliders to change the Scale and the Offset from the trace.
Data can be clamped, e.g. all values above the set maximum value will be set to the maximum value.
If there are negative values in the data, they will be displayed on the graph with a value of zero.
Downhole points can be displayed as a line, and you can change the Colouring, Scale and Offset of the line:
Downhole points displayed as a line graph beside each well, with the Colouring, Scale and Offset of the line set in the Well Graph Style Manager
All changes made in the Well Graph Style Manager are automatically updated in the scene so you can experiment with the settings. Once you have closed the window, you can also change the Scale and Offset by clicking on the graphs object in the shape list:
The graphs object selected in the shape list, with Scale and Offset sliders available in the shape properties panel.
To select a different column to display, open the style manager by double-clicking on the graphs object in the project tree or select a new column from the shape list.
If you are working in a new project into which you have just imported wells, the Well Graph Style Manager will open when you add it to the scene. If the Well Graph Style Manager does not open when you add the graphs object to the scene, it is because the styles have already been set, perhaps by another user. You can change them by double-clicking on the graphs object.
