Fill Grid Dummies Using Minimum Curvature
The function fills dummy values in a grid file by using polynomial or local median initialization followed by minimum curvature iterations.
On the GM-SYS 3D Tools menu, select Grid Editing.
Select Fill Grid Dummies using Minimum Curvature. The Fill Grid Dummies using Minimum Curvature dialog appears.
From the Grid file to be plugged drop-down list, select the input grid file. Alternately, you can browse to the file.
In the Output grid file field, specify the output grid file.
From the drop-down list, select the Order of initializing polynomial. The options are 0 to 3, or use -1 for local median replacement.
Enter the Number of minimum curvature iterations. The default is 100.
Click OK. If the output file already exists, you will be asked to overwrite it. The requested changes are made.
