Edit a Density-Depth Table
Select a Density-Depth Table (DDT) in the DDT tab of the Model Explorer and the table will be displayed in the Properties panel. You may edit the values in the table.
The offset is relative to the "reference" surface and must be increasingly negative value with depth. Invalid entries will be flagged as errors and must be fixed in order to change the table.
Edit a Density Depth Table
From the DDTs tab in the Model Explorer, select the Density-Depth Table to edit.
In the Properties pane, on the right side of the Model Explorer you can edit the Offset and Density as required.
Click Apply. The changes are saved to the selected Density-Depth Table.
