Export a Density-Depth Table
Export a Density-Depth Table to an ASCII file containing offset-density pairs. Header lines will indicate which fields contain offset and density, as well as the units used.
Export a DensityDepth Table
From the DDT menu select Export DDT. The Export DDT dialog appears.
From the dropdown list, select the DDT to export.
Click OK. The Export Density-Depth Table to a Text File dialog appears.
Specify the Output text file name and location.
Add any comments, if desired.
Click OK. The Density-Depth table is exported.
Export Density-Depth Table dialog options
Output text file |
Specify the text file to be created |
Comments |
Optionally enter free-form comments to be included in header fields in the file. |
