Export a Body from a GM-SYS 3D Model
Use the Body > Export Body option to export any information about the selected body to formats that are appropriate to that data type.
Export Body dialog options
Body |
Select the body that you want to export |
Parameter |
Select Shape, density, or susceptibility. |
| Defined by |
This is a read-only display of the data type currently being used to define the parameter in the layer. |
| Export as |
Select the output data type. The possibilities are limited by the fields above. |
| Output <file> name |
Specify the output file name of the type specified above. |
The table below specifies the possible export possibilities, given a selected body, parameter, and how that parameter is currently defined.
If the parameter to export is: |
And the current source is: |
It can be exported to: |
Shape |
Geosurface | Geosurface | ||||
| Density |
| Susceptibility |
