SEG-Y Configuration Files
The SEG-Y Configuration workflow produces a configuration specific to the SEG-Y file currently loaded. You may save the configuration to a file on disk, so that subsequent reloading of the SEG-Y will not require repeating the configuration process.
By default, SEG-Y Reader looks for and automatically loads the configuration file with the same name as the SEG-Y file being loaded and the extension ".segy_config" appended to it.
From the Configure menu, select Load Configuration to specify a configuration to load.
