The Imago Core Photo Interface
This topic describes how to set up and use the Imago core photo interface. It is divided into:
Setting Up the Imago Interface
Before you can view core photos, you must first set up the link between Leapfrog Geo and the Imago database. To do this, right-click on the Drillhole Data folder and select Add Core Photo Link. In the window that appears, select Imago and click OK.
The Imago Settings window will appear.
Imago supports Seequent ID, and so the Subscription name list displays all the subscriptions your Seequent ID has access to.
Each of the fields in this window must be set in order for Imago to display corresponding imagery when an Imago link is displayed. Once you have selected which subscription you wish to link to, choose a workspace, a dataset, an imagery type and an image type.
Finally, select whether each core photo will be opened in a separate browser Window or Tab.
Click OK to save the information. The Imago Link button (
) will appear in the toolbar:
A link will also appear in the project tree as part of the Drillhole Data folder:
Using the Imago Interface
To view core photos, click on a drillhole in the scene, then click on the Imago Link button in the window that appears:
Your browser will be launched and you will be prompted to log in to the Imago database. Remember to allow the browser to save the details so that you will not be prompted to log in each time you wish to view a photo.
) in the toolbar allows you to view core photos in your browser in rapid succession. To do this, first make sure you are already logged into the database. Then click on the Imago Link button (
) to enable the rapid viewing mode. Each time you click on an interval in the scene, the core photo link will open in your browser.
Position your browser window alongside the Leapfrog Geo scene window to view drilling data in Leapfrog Geo alongside the core photo data.
Removing the Imago Link
To remove the Imago link, right-click on it in the project tree and select Delete.
